Hot shot with a Utilmaster step van MT45 cummins
Discussion in 'Expediter and Hot Shot Trucking Forum' started by supernova, Jun 7, 2014.
  1. supernova
    supernova Bobtail Member
    38
    18
    Jan 11, 2014
    Calgary AB
    I just wondered if any guys have had any experience hauling a cargo trailer with a mt45 Freightliner ( Step Van) . I mean it seems a good choice with it's 5.9 cummins 24 valve and Allison trans plus a rear end that's nice and low. It's a dually so should be the ideal choice right?I can't find many reasons not to use the step van apart from it looks ugly and not as cool as a dodge dually but hey $10k to purchase as to about $20k for a ram, seems a great move . I can't use a goose or fifth wheel, that much is obvious but extra space means cash.I was thinking of a enclosed 28ft . Throw some suggestions in .Supernova.
  3. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    Slice half the box off to expose the frame, put a fifth wheel or goose neck on it. The rest of the box turn it into a sleeper.
    supernova Thanks this.
  4. supernova
    38
    18
    Jan 11, 2014
    Calgary AB
    lol. But think it would just enhance the old girls ugliness. But like your thinking.
    Supernova
  5. Lite bug
    Lite bug Road Train Member
    1,391
    28,672
    May 3, 2014
    Columbus Ohio
    Tag along trailer would work. You would have huge sleeper.
  6. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    1. It's probably not geared to pull a trailer, 2. You'll be pushing a lot of air with it which means bad fuel mileage, 3. Sometimes cheap isn't always better.
    LGarrison and supernova Thank this.
  7. flatbedcarrier
    flatbedcarrier Medium Load Member
    667
    826
    Jun 8, 2005
    Southern California
    I've owned a few step vans that I turned into Mechanic trucks. The wind will get you.
  8. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,842
    Jul 28, 2011
    Glasco,Ks.
    I don't think many of those step vans had a decent power rating on the motor, may have to spend some money to get it uprated/tuned.
  9. Bobble
    Bobble Light Load Member
    100
    130
    Nov 26, 2013
    Let me look and see.
    The lower deck will help you if the loading is done by hand or hand truck (assuming you have a ramp). How hard do you want to work? It will also prohibit you from full pallets or other loads shipped/received where a dock is required. (see 2nd sentence) The lighter weight of the van will factor in wind blown storms. A van is a cold ride in the winter. Do you plan on building some sort of partition behind the seat? On a good note, you can think about installing a generator underneath and a RV size heater/AC unit on the roof.
  10. SHO-TYME
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    B y the time you get done modifying it and doing everything else, you could of been in a decent truck and be rolling.
  11. LGarrison
    LGarrison Road Train Member
    1,246
    995
    May 19, 2011
    Sandpoint Idaho
    With the 5.9 all you need is a bully dog run it in tow mode 400 hp.
