HOS after Hometime question
Discussion in 'Trucking Industry Regulations' started by aries, Jun 19, 2009.
  1. aries
    aries <strong>"Ram Tough"</strong>
    26
    Farmville, VA
    After looking at the reg's i think i know the answer but would like a more knowledgable person to verify. In the past with freight moving better this was not a problem but now it is. Here is the situation:
    - I take the rig home and launch from the house.
    - Once i am sent home i am given a time and date to check back in when my home time is up.
    - For example i am told to check in at 0630 on a thursday and to keep checking the box every hour for a load.
    - after 8:30 p.m. i can quit checking until the following morning.
    - the box powers off after one hour and i have to turn the key on the truck to power it back on the check for msg's / loads.
    The problem is that i may not get a load until 8:00 pm and i am expected to be ready to drive for 11 hrs. The load I get is structured as if I will start my day when I receive the load info.
    I have not been able to rest having to power up the box and check for a load every hour. Obviously at this point I am tired and not really fit to drive 11 hrs.
    When I made this point to my dispatcher and asked if there was a better way the gist of his answer was that this is the way it is and while i did not have to stay in the truck the entire time i still need to check the box ever hour or so.
    After looking at the reg's I came to the conclusion that I should send in my start of day msg and go On Duty Not Driving at the time I am required to check in thereby starting my 14hr clock.
    Thanks for any help you can provide on this. I'll respond to any answers as best I can with the limited time I have.
  3. dancnoone
    dancnoone "Village Idiot"
    9,922
    3,713
    May 6, 2007
    Explain to your dispatcher, that technology has advanced further than his pea sized brain can comprehend. IE He can not grasp more than one thing at a time.
    Satellite communication has been around fewer years, than the telephone has.
    Then send him a pack of gum, and instruct him to try chewing a stick while walking. This will increase his productivity by at least 50%
    Wiseguywireless and panhandlepat Thank this.
  4. psanderson
    psanderson Road Train Member
    1,029
    402
    Oct 13, 2008
    Moline, Illinois
    Once you look for the message you are legally on line 4. Here's the rule:
    TITLE 49
    TRANSPORTATION CHAPTER III
    FEDERAL MOTOR CARRIER SAFETY ADMINISTRATION
    DEPARTMENT OF TRANSPORTATION
    PART 395
    HOURS OF SERVICE OF DRIVERS
    Table of Contents
    Sec. 395.2 Definitions.
    On duty time means all time from the time a driver begins to work or is required to be in readiness to work until the time the driver is relieved from work and all responsibility for performing work. On duty time shall include: (1) All time at a plant, terminal, facility, or other property of a motor carrier or shipper, or on any public property, waiting to be dispatched, unless the driver has been relieved from duty by the motor carrier; (2) All time inspecting, servicing, or conditioning any commercial motor vehicle at any time; (3) All driving time as defined in the term driving time; (4) All time, other than driving time, in or upon any commercial motor vehicle except time spent resting in a sleeper berth; (5) All time loading or unloading a commercial motor vehicle, supervising, or assisting in the loading or unloading, attending a commercial motor vehicle being loaded or unloaded, remaining in readiness to operate the commercial motor vehicle, or in giving or receiving receipts for shipments loaded or unloaded; (6) All time repairing, obtaining assistance, or remaining in attendance upon a disabled commercial motor vehicle; (7) All time spent providing a breath sample or urine specimen, including travel time to and from the collection site, in order to comply with the random, reasonable suspicion, post- accident, or follow-up testing required by part 382 of this subchapter when directed by a motor carrier; Performing any other work in the capacity, employ, or service of a motor carrier; and (9) Performing any compensated work for a person who is not a motor carrier.
    Numbers 1 and 4 are applicable here.
    The permission to be off duty as shown above must be in writing.
    From a retired federal DOT official
    aries and 94nole Thank this.
  5. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Your dispatcher doesn't have a telephone? Why fire up the box just to see nothing?
    I would call, and keep calling, or better yet, print out psandersons response, show it to them and prove they have started your 14 on the first check...they should be calling you if they have sent you home to await your next dispatch...in a sense they are pushing you into a corner with a log violation.
    aries and panhandlepat Thank this.
  6. psanderson
    1,029
    402
    Oct 13, 2008
    Moline, Illinois
    The written permission in this instance would also be inapplicable as it may only be used for meals and other such short periods. These time periods also count toward your 14-hours pursuant to the definitions found in part 395. Also note the authorization also only allows a driver to do this for routine stops which means that it is only applicable while on the road.
    This letter authorizes our driver to be Off-Duty during meal and other routine stops.
    The purpose of the Federal Department of Transportation Hours of Service Regulations
    (Part 395) is to keep tired drivers from operating vehicles. Under certain circumstances,
    however, it appears that enroute stops for meals or other routine purposes may serve to
    lessen a driver's fatigue.
    Therefore, this letter is authorization for you to record your meal or other routine stops on
    your logs
    as Off-Duty, rather than On-Duty Not Driving as would normally be the case.
    However, this may be done only under all of the following circumstances.
    1. Your vehicle must be parked in a safe and secure manner so as to prevent
    obstruction of traffic and theft or damage to the vehicle and cargo.
    2. The off-duty period must be no less than 30 minutes and no longer than 60
    minutes.
    3. During the off-duty period, you are relieved from responsibility from your vehicle
    and cargo.
    4. During the off-duty period, you are free to leave the premises on which your
    vehicle is parked and to pursue activities of your choosing, as long as your ability
    to safely operate your vehicle is not impaired as required by Part 392, "Driving of
    Vehicles", of the Federal Motor Carrier Safety Regulations.
    Driver Supervisor Name and Date
    aries Thanks this.
  7. Mike_MD
    Mike_MD Medium Load Member
    352
    240
    Feb 4, 2009
    O-Zone
    *Question 31: If a driver is required repeatedly to respond to satellite or similar communications received during a 10-hour (8-hour for passenger transportation) off-duty period, does this activity affect a driver’s duty status?
    Guidance: Yes. The driver cannot be required to do any work for the motor carrier during the 10-hour or the 8-hour off-duty period. A driver who is required to access a communications system for the purpose of reading messages from the carrier, responding to certain messages (either verbally or by typing a message), or otherwise acknowledging them, is performing work. For the purpose of this guidance, “repeatedly” means a pattern or series of interruptions that prevent a driver from obtaining restorative sleep during the off-duty period.
    Be safe.
    panhandlepat and aries Thank this.
  8. aries
    26
    Farmville, VA
    From now on I will be starting my clock when I check in, etc. If this causes heartburn for the company so be it. I do not want to injure anyone because I am not fit to drive.
    As I mentioned I was pretty sure I knew the answer after getting to "Sec. 395.2 Definitions" but not being a lawyer I needed a second opinion.
    I never spotted question 31. thanks
    I'm still fairly new at this and still learning when to speak up. When I asked my dispatcher about this matter the response I got made me feel like I was talking to a used car salesman or worse a politician. Hence my going to the reg's.
    Again, thanks to everyone for the assistance.
  9. aries
    26
    Farmville, VA
    And special thanks to psanderson and Mike MD for taking the time to quote the reg's
  10. LostSoulCA
    LostSoulCA Medium Load Member
    343
    150
    Apr 7, 2009
    Visalia, CA
    I read the regs and agree that the dispatcher and associated manager should use the phone to improve efficiency and team spirit... That being said, couldn't this be considered picking nits and just make it tougher on the driver?
  11. panhandlepat
    panhandlepat Road Train Member
    3,255
    2,243
    Jan 12, 2007
    thank GOD the Co. i am with now will not even send a msg on your 10. they wait till you have gotten on the highway so ya have to pull over LOL. we also get a preplan before we even get to the house for hometime.
    at USA i had to get to my truck, send in a "return to work" macro and wait "usually in the sleeper) for a load sometime up to 5 hours.
