Should a clutch fan spin freely when the engine is off?
Cummins isx 475 Horton clutch fan in 2006 International 9900.
Horton clutch fan
Discussion in 'Trucks [ Eighteen Wheelers ]' started by taxihacker66, Mar 2, 2016.
Page 1 of 3
No not always .
It depends how the oem has the selinoid wired. It could be commanded on with ign switch in the off position.
Depends on manufacturer. Some do some Don't.taxihacker66 Thanks this. -
Horton Drivemaster fan hub is spring apply, air release so shouldn't spin at key off. do simple test, run engine and engage manual fan switch at 1500 rpm should hear the fan cut in if working correct.
clear as mud, ain't it
Trying to figure out if the clutch fan is faulty.
There's a bearing screeching noise from the front of the engine. I took the belts off and everything spins freely and theres no excessive(wobble) movement on anything. I replaced both belts and the noise is still there.
The fan will come on when the engine hits 210 and it will come on when I manually turn it on.
But there's also a noise (pssht) when I turn the engine off .It's the same sound when I would have the fan manually turned on and forgot to turn it off before shutting the engine off. -
That pssht noise is the power to the solenoid being turned off,and air exhausting.
Page 1 of 3
