Hop issue around 60-65mph
Discussion in 'International Forum' started by dom14, Apr 29, 2017.
  1. dom14
    dom14 Light Load Member
    66
    10
    Oct 18, 2016
    Past few months I've been trying to track down where the hop as been coming from on my truck.. happens around 60-65mph.. tires show no wear alignment and tire guys both find no issues.. I did a lot of bobtailing yesterday and truck ran smooth with no hops.. so obviously trailers are playing a part in this.. could it be a fifth wheel issue? And would bad shocks cause this?
  3. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    The shocks job is to dampen the ride and keep the tires planted on the ground.
    If you've never replaced them, I would recommend it.
    Also check the torque arm bushings.
    strollinruss Thanks this.
  4. Hogleg
    Hogleg Medium Load Member
    311
    258
    Nov 20, 2016
    Salem, Illinois
    Carrier bearing?
  5. Slay
    Slay Light Load Member
    131
    134
    Jan 7, 2015
    Try rotating the tires. I figured out my truck hops due to a couple of bent rims and when they were rotated the hopping changed.Tires and rims look good standing still.
  6. Espressolane
    16,960
    102,188
    Did the tire guys check run out? when a tire goes out of round, it can be hard to see, just looking, need to run a gauge on it.
  7. AModelCat
    154,213
    If it runs smooth bobtail and hops with any trailer, I'd check that the leveling valve is working correctly if you have air ride. Not sure what suspension you have or what the spec is for ride height but measure it bobtail and loaded. Should be the same or very close. If the truck sits noticeably lower with a loaded trailer that could possibly be the issue.
  8. dom14
    66
    10
    Oct 18, 2016
    My drivers side mirror shakes like a SOB when the hops start. I need to go to a new tire shop bc the last place jacked up spun the tire and said it was fine. Thank you will update when it's resolved. So if the steer tires are out of round how come it doesn't hop when bobtailing
  9. woolybully35us
    woolybully35us Medium Load Member
    313
    550
    Mar 13, 2015
    ks
    I had the same problem. it was trailer tires. but I pull the same trailer all the time.
