hood/front end questions for 94' fld 120
Discussion in 'Freightliner Forum' started by thebigugly, May 2, 2013.
  1. thebigugly
    thebigugly Bobtail Member
    I just recently purchased a 94 fld 120 w/ non-integrated sleeper and was trying to give it a face lift! The hood is busted and the truck could use a paint job! This leads me to the next question can a classic hood fit on this truck without to much modification? Does anyone have pics of this done? I'm new to trucks with lots of questions so please don't bash on me to bad.
  3. Big_jon
    Big_jon Light Load Member
    139
    60
    Apr 12, 2013
    Not alot of people would know. Start a google search. Get dimmensions of your current hood and compare them to the one you want. Might take a little time. Try typing this into google "dimensions of (hood on truck model and make).
    Goodluck
  4. carrkool
    carrkool Heavy Load Member
    883
    495
    May 10, 2012
    adah, pa
    it depends on what fld120 you have. they did make a set forward axle that you could get a short nose classic hood. Otherwise you have to change the frong springs, move the axle forward and get the hood. personal I hate the short nose classic as the fenders sit way up high not like your more commonly seen classic xl which is a 132
    But if you want to make it look good get a new hood, get a drop down chrome wrap around bumper 22in drop get the stainless hood wraps like classics have and the chrome for the headlight area. a drop visor with lots of lights move the stacks to the cab sides and get the light bars there. lights up the back fairings and bunk area. lights under the bunk area shining on the tanks.lighted mud flap hangers....does your truck have skirting or open tanks. if its skirting mount 2 in seal beams down on the lower part at the seam.....I can go on more....lol
    ducnut Thanks this.
  5. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    you can use the classic hood if you have the front springs and frame extenders would take alittle time but can be done
  6. thebigugly
  7. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    You can mount a F/L Cabover cab on an FLD chassis by changing the front frame extenders/ spring hangers so I'm sure a Classic hood will fit as well. The bolt pattern should be the same. Since both are 120" BBC, the cab should be in the right spot in the frame.
    But not all Classics are the same. They were changed around 2002 and made to mount on a Century chassis. If the Classic bumper has 2 sort of square holes for tow hooks it's the new style if it has the horizontal oval in the center with a tow pin it's on an FLD chassis.
  8. Cowboy Preacher
    Cowboy Preacher Bobtail Member
    Hey the big ugly,
    How did it go? What did you do? I am looking at doing the same thing.
  9. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,024
    Dec 31, 2010
    Washington, PA
    That post was in 2013. The poster left 2 days later. You won’t get an answer.
    QUALITYTRUCK and Last Call Thank this.
  10. Last Call
    Last Call Road Train Member
    7,568
    45,898
    Mar 15, 2021
    Rumor is that he was committed to a mental institution..& he proved that you can put a square peg in a round hole ..
    They also claim he holds the championship trophy at the institution for the jug saw puzzel completion..
    JoeyJunk Thanks this.
