Home sub woofer in truck
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by joseph1853, Apr 10, 2018.
  1. joseph1853
    joseph1853 Road Train Member
    1,003
    562
    Dec 12, 2010
    Waco, TX
    Ok 2015 international lease truck through ryder with the apu and inverter included.. thinking about running a home sub woofer in the truck powering it with the stock inverter. Im sure it has enough power to run an amplifier that would power the sub with no problem as it has no problems with a microwave which requires a large amount of juice. just thinking it would be easier to plug a self powered home sub into the inverter then it would be to install a car audio amp with all the wiring.. not sure about the sound though.. i guess that's my main question what will it sound like. im assuming it will sound fine if not fantastic considering it's designed for a larger room so putting it into a smaller room will not limit it like putting a speaker in a bigger room meant for a smaller room. any truck driver audio files out there? lol..
  3. Diesel Dave
    8,701
    24,852
    Jan 20, 2010
    Hesperia, Ca.
    Hmmmmm, I wouldn’t know, I’m runny 2 Memphis amplifiers. 1 for my subs and other for components. Concert hall in my truck every day. Let us know how it sounds.
  4. nax
    nax Road Train Member
    1,999
    2,253
    Dec 14, 2016
    Whhhaaaaat?? @Diesel Dave having a kick-axx stereo in the truck???
    Now that I got to see. Pics or it aint there.
  5. Maj. Jackhole
    Maj. Jackhole Heavy Load Member
    807
    4,202
    Mar 19, 2017
    Given this much thought myself. Downside is the constant vibrations in the cab; how do you address that without hurting the sound quality in certain cases. Looked at the little Bose 123 system the sub/processor case seems to be stout enough. love to hear what others have done that are comany drivers and can't get deep into audio systems.
    joseph1853 Thanks this.
  6. DUNE-T
    DUNE-T Road Train Member
    6,943
    16,844
    May 10, 2015
    Detroit, MI
    I just got a 8" bazooka, which gets power from radio wire. Good headunit, good speakers and the sound is very acceptable
    joseph1853 and Sho Nuff Thank this.
  7. Diesel Dave
    8,701
    24,852
    Jan 20, 2010
    Hesperia, Ca.
    You darn skippy I do, will take pix tomorrow. Stay tuned......
    Cottonmouth85 and SAR Thank this.
  8. mhyn
    mhyn Road Train Member
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    D.Tibbitt, x1Heavy, joseph1853 and 4 others Thank this.
  9. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    x1Heavy, joseph1853 and mhyn Thank this.
  10. mhyn
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    i have tried few systems and this setup was the best. I like clear sound with solid bass.
    x1Heavy, joseph1853 and SAR Thank this.
  11. Sho Nuff
    Sho Nuff Road Train Member
    1,175
    1,401
    Apr 9, 2015
    The easiest, most simplified way to add a subwoofer is to probably add a Preamp Subwoofer...something that has an amp built into already. I used a Preamp Sub years ago in a daycab. Setup was extremely easy...hooked up the speaker wire into the sub and bought a 12v plug in adapter and hooked it right into the 12v cig lighter and...voila...instant bass....
    https://www.amazon.com/Bazooka-BTA10100FHC-10-Inch-Powered-Subwoofer/dp/B003E4Q0E4
    https://www.amazon.com/BassPro-SL-Under-Seat-Subwoofer-Enclosure/dp/B01ABC5NVM
    joseph1853 and Maj. Jackhole Thank this.
