Holland Fifth Wheel Problems
Discussion in 'Experienced Truckers' Advice' started by JC1971, Feb 25, 2019.
  1. JC1971
    JC1971 Road Train Member
    2,607
    9,297
    Jul 29, 2013
    L.A.
    I have a 2019 Kenworth with a Holland fifth wheel. In the almost one year I've had it, it's been in the shop four times because of fifth wheel problems.
    It seems to be a common problem with the air cylinder that prevents the fifth wheel from releasing and also locking. Pulling on the manual release doesn't help because it's stuck in there like Excalibur.
    With great difficulty, I can eventually get it to release then when hooking it won't lock, but sometimes it will.
    At that point, I don't want to pull any more trailers until it gets looked at because, obviously, I don't want to drop a trailer in the middle of the highway.
    A mechanic at our shop said it wouldn't release once it's locked but I'm not willing to chance it. Does anyone know enough about fifth wheels to know if this is true or not?
    I'm of the opinion that fifth wheel issues need to be looked at immediately because the consequences are too great if it fails, but I don't know enough about them to know if what he said is true or not.
  3. Deere hunter
    1,847
    7,734
    Aug 5, 2017
    Shallowater Texas
    A brand new aluminum Holland fifth wheel is $2000 it would’ve saved you a lot of downtime! My steel Holland was doing the same thing wouldn’t unlock hard to lock so I just got rid of it, mostly for safety sake !
    JC1971 Thanks this.
  4. PE_T
    PE_T Road Train Member
    I’ve been sliding 5th wheels a lot. Most people just leave the 5th wheel in the sweet spot, and never move it again. I slide it forward most of the times I am deadheading for fuel efficiency purposes and sometimes when on light loads. Otherwise, I leave it in the sweet spot.
    Most 5th wheels need a little bit of lightly tugging back and forth to get the pins to release. Also, try turning on/off the 5th wheel switch. If you are loaded, you must drop your landing gear and deflate your airbags for a few seconds—only. Do NOT leave it deflating for too long as the king pin can come off or possible get stuck and damage the 5th wheel.
    If you still can’t move it, turn off the 5th wheel switch and air up your air system to the max (about 135 PSI). You should be able to hear a popping sound when your system maxes out. Then try it again. It can also help to go for a short drive to get the air to fully circulate the truck.
    The other possibility is that there may be a serious air leak in the 5th wheel system. You can spray the airline fittings coming out underneath the 5th wheel with soap and water.
    One last pointer, you can actually grease the sliding mechanism of the 5th wheel. It helps your 5th wheel slide very smoothly.
  5. Mango1281$
    Mango1281$ Bobtail Member
    4
    Feb 19, 2019
    That is not true I had a holland 5 th wheel spring go bad luckily I felt the it when it released and stopped in time to catch the trailer on the frame but I company wasn’t lucky enough to get another truck there before DOT SWEENEY in Greenville Kentucky shut the small town down to do an inspection he determined I needed a new 5th wheel and that a 1200 dollar fine was sufficient for the crime I’m just glad no one was hurt and I didn’t lose any points.
    JC1971 Thanks this.
  6. Hebrew Hammer
    Hebrew Hammer Bobtail Member
    10
    Does anyone know if the slider part of a fw35 holland should have latterial movement in that channel it slides on? (Hope I explained it ok)
  7. TJB15
    TJB15 Light Load Member
    67
    115
    Apr 29, 2020
    Not sure exactly when you are having trouble but when dropping loaded trailer dump air in trailer before you lower landing gear as trailer will move forward several inches unless equipped with some kind of a automatic block between frame and axel. I generally do this with tractor brakes released to allow it to roll forward easily. Once air is exhausted you can then put truck in reverse and back into kingpin as far as possible then set tractor brakes this will give you the best chance of unlatching it. If that doesn't work and you also have trouble getting it to lock it sounds as though it is adjusted too tightly. If when latched the handle isn't all the way in it is definitely not to be trusted. Once handle is all the way in it is highly unlikely to come unhooked unless you high hook it which should be fairly obvious as the trailer plate won't be all the way against the tractor plate. While it is possible to rebuild a fifth wheel I have seen negative results with dramatic consequences. I'm assuming this is a new plate from factory.
    JC1971 Thanks this.
  8. JC1971
    2,607
    9,297
    Jul 29, 2013
    L.A.
    That's a good tip to know as far as dumping air first before lowering landing gear. I'll have to try that from now on.
    That was a year-old fifth wheel at the time. It ended up being replaced with a Jost fifth wheel that didn't give me any problems after that.
  9. Blackfly
    Blackfly Bobtail Member
    47
    25
    Jun 1, 2014
    The woods, Connecticut
    I found this because I just dropped a loaded trailer. ( the bad way). I’m lucky the gear, although badly damaged, held up. I’m a little shook because it’s my first “accident” and I’ve been hauling tankers for over 10 years in every kind of weather except a tornado. Well another company driver was here and I had done 3 tug tests, 2 with gear up 2” then another before moving. I still can’t say for sure what happened but I know I wasn’t high hooked ( always look first) and the pin was in after the trailer went down. So somehow it may have gotten into locked position first, but then why did the tugs hold ? Still a little baffled and a little nervous about re-hooking after they unload the trailer. With the tractor bags down all I will need it two 2 by 4’s to sneak it up to the plate.
