Holland 5th wheel slider
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Klleetrucking, Dec 28, 2010.
  1. Klleetrucking
    Klleetrucking Medium Load Member
    378
    346
    Dec 11, 2010
    S.C.
    I'm painting the back of my frame and am going to get the slider sandblasted.
    Curious, how do you remove the air cylinder from the sliding assembly?
    I've got the fifth wheel off so it's easy to see.
    Any special tools? I used the search fuction and no results.
  3. mgfg
    mgfg Road Train Member
    1,753
    626
    Mar 29, 2010
    A bolt and nut at each end of the air cylinder.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    No special tools... just wrench and socket with ratchet.
    it is held with bolts/nuts
  5. Klleetrucking
    378
    346
    Dec 11, 2010
    S.C.
    ^^^^^^^^Not that easy guys.^^^^^^^^​
    I did get it out, but had to fab up a spring compressor to collapse the two springs to get to the 1/2" pin that attaches the cylinder to the "locking dogs". It's an ingenious failsafe design holding the pins in place but not a lot of fun to disassemble.
  6. carontech
    carontech Bobtail Member
    edmonton
    yes ur right, to compress the dawg springs there is a special c-clamp tool u can buy, but a regualr clamp will usually work fine. the bolts in the end of the dawgs are to set the adjustment in the slider track. the bolt stop the dawgs from pushing in tight in the track, there should be a bit of slack (or play) between the dawgs and the track so they dont seize in the track.
