Hole in fuel tank for 2017 Kenworth T680
Discussion in 'Kenworth Forum' started by tatotrucking, Jul 7, 2021.
  1. tatotrucking
    tatotrucking Bobtail Member
    Hello, I don't know how to explain this, but my driver hit a rock or something, and managed to create a hole in the bottom of the driver's side fuel tank. Any suggestions on how to fix this problem? Can we bypass that fuel tank in any sort of way? JB Weld the bottom, where the hole is? Any help will be appreciated, thank you.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    If you have twin tanks block off the lines the that tank. Put fuel in the other one and rock on tell you get home.
    Do not forget to call the EPA and report your fuel leak.
    spsauerland Thanks this.
  4. Capacity
    Capacity Road Train Member
    1,499
    3,116
    Jul 28, 2019
    Neenah Wi
    I remember ole Tom stuck a carrot in the hole to get him to the shop , and it worked.
  5. okiedokie
    okiedokie Road Train Member
    11,677
    84,529
    Jun 13, 2011
    PNWET
    I used a rag & a stick.
  6. SmallPackage
    5,274
    16,447
    Dec 20, 2019
    Marion Texas
    If its a small hole that you can jamb a screw into and you don’t have one laying around. Take one out of a door panel or dash in a pinch.
  7. AModelCat
    154,267
    For a permanent repair I'd take the tank off and take it to a shop that welds aluminum. They can probably flush the tank of flammable fluids/vapours and then weld up/patch the hole.
