Holbrook to Phoenix?
Discussion in 'Experienced Truckers' Advice' started by tracyq144, Aug 10, 2010.
  1. tracyq144
    tracyq144 Heavy Load Member
    884
    546
    Feb 15, 2009
    MN
    I was going to take 77 south to US60, but chickened out at the last moment (the few replies I got on the CB advised against it), and went through Flagstaff instead. 77/60 is approx 40 miles shorter, but I don't know if it is any faster (probably not).
    Anyone do this alternate route? Good, or bad?
  3. Old Man
    Old Man Road Train Member
    4,597
    13,469
    Apr 3, 2009
    Oklahoma City, OK
    You did the right thing. Probably saved 2 hours.
  4. lego1970
    lego1970 Medium Load Member
    504
    165
    Oct 10, 2008
    Blue Springs, Missouri
    It's a nice drive and I used to take it a lot, but it's hilly and twisty in areas, plus you have to go thru Grayson?, and more lights when you get into Pheonix.
  5. BIG RIGGER
    BIG RIGGER Road Train Member
    1,071
    414
    Feb 25, 2010
    Fargo,ND.
    I went that way once routed by CFI.I must have seen 500 Swift trucks.They all go that way.
  6. Stump
    Stump Heavy Load Member
    769
    663
    Jan 27, 2009
    Modesto CA
    AZ77 south to AZ377 south to AZ277 south west to AZ 260 west to AZ87 South, I run it all the time, good running road. Takes about the same time as running the interstate. Don't listen to the interstate monkeys. great drive too.
  7. Rollover the Original
    Rollover the Original Road Train Member
    3,206
    2,712
    Jul 1, 2009
    Springfield,MO
    Wonder which one costs less to drive? go one way and make notes and then the other and take notes!
    LoneCowboy Thanks this.
  8. jerryy123
    jerryy123 Light Load Member
    51
    4
    Feb 22, 2012
    77/60 is the shortest and fuel prices now days gives u no chance to go the longway around.:biggrin_25526:
  9. Gearjammin' Penguin
    2,587
    7,697
    Feb 18, 2007
    Central AZ
    Why on Earth would you even consider 77/60? :biggrin_2556: Stump's reply gives you the best way to go unless there's a blizzard on the Rim.
    FerrissWheel Thanks this.
  10. moonerman
    moonerman Bobtail Member
    22
    May 29, 2013
    Thank you so much. I can't log that many miles tonight going thru flagstaff and was wondering if this was a legal truck route. I don't care about more time because I'm on paper logs. Pulling a flatbed loaded heavy. Any hard pulls thru that area?
  11. fargonaz
    fargonaz Road Train Member
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    It didn't use to be so cut-and-dry, az377 used to have a 30 ton weight limit.
    Better yet, if delivering to the east valley, take NM117(I-40 MM 89) to NM36 to US60, awesome scenery with El Malpais National Monument and the Salt River canyon.
    moonerman Thanks this.
