Hitting tires with hammer? Wtf
Discussion in 'Questions From New Drivers' started by 1029384746, Aug 3, 2018.
  1. 1029384746
    1029384746 Light Load Member
    77
    45
    Oct 15, 2012
    I know you can't do this caveman ritual at the DMV. so how does hitting your tire with a hammer give u an advantage?
    Why not get out and use a tire gauge?
    Why do people do this?
  3. MBAngel
    MBAngel Medium Load Member
    516
    952
    Apr 1, 2018
    Tucson, Arizona
    They're listening to the sound of the thump. A tire low on air pressure sounds dull. A full tire makes a slight pingy sound. If you hear one that sounds different, then you use the tire gauge.
    Dennixx, Tb0n3, MartinFromBC and 25 others Thank this.
  4. Zeviander
    Zeviander Road Train Member
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    You can't gauge a hot tire, you won't get an accurate reading. The sound of the thump from a hammer or mallet will tell you far more on a hot tire than a gauge will.
    Gauge them when they are cold, thump 'em when they are hot.
  5. #wishfulthinking
    #wishfulthinking Light Load Member
    203
    551
    Jun 9, 2018
    Central Iowa
    @Zeviander & @MBAngel are both correct. I've been hitting my tires with a hammer for years and don't intend to stop anytime soon. I keep a hammer and a tire guage in my drivers side door. Both get used daily.
    slow.rider, Dan.S, JTAN and 14 others Thank this.
  6. Zeviander
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    Just don't hit the tire with the claw end! LOL
    Fuelinmyveins, Dan.S, Ffx95 and 15 others Thank this.
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Highest pressure I was able to discern as being a low tire was 63lbs using a 4 lb hammer. Which is pretty low.
    Meaning, anything above that seemed okay using the hammer even though a tire could be up to 37 lbs low before you would notice it with a hammer.
    But it still caught it before it blew.
  8. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Plus, in addition , gauging a tire actually has a chance to deflate the tire. Dirt gets in the stem, gauge opens the valve, but the dirt falls in and keeps the valve slightly open. Not a fast leak, but even with caps on it can drain a tire in a few hours.
    slow.rider, AModelCat, O.Henry and 6 others Thank this.
  9. #wishfulthinking
    203
    551
    Jun 9, 2018
    Central Iowa
    Lol
    MBAngel Thanks this.
  10. ZVar
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Might want to go get your hearing checked and a hearing aid. I can easily tell the difference between 80 and 100 lbs Depending on conditions, I could tell 90 to 100 lbs, although I will admit that's rare.
    Ffx95, Coover, DTP and 6 others Thank this.
  11. JC1971
    JC1971 Road Train Member
    2,607
    9,304
    Jul 29, 2013
    L.A.
    If your trailer has a tire inflation system, can't use a gauge.
