Hissing at the dashboard
Discussion in 'Ask An Owner Operator' started by dphillips, Apr 20, 2015.
  1. dphillips
    dphillips Light Load Member
    82
    8
    May 14, 2013
    I have a 2007 Volvo 670 .and every time I apply the trailer air I started hearing a hissing.it's not effecting my air supply really but there is just noise at the dash doesn't happen when bobtailing .any info would be helpful thank you.
  3. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    If the hissing is continuous, and doesn't stop shortly after applying trailer/emergency air, then it's likely a leak somewhere on the trailer (especially pancake diaphragm).
    Do a normal DOT leakdown test with the trailer attached, and see if your air pressure holds.
  4. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    rollin coal and 77fib77 Thank this.
  5. rachi
    rachi Road Train Member
    4,246
    5,228
    Feb 25, 2010
    SoCal
    Im with heavy haul, might be a big snake up in there waiting for you to go to sleep.
  6. spindrift
    spindrift Road Train Member
    3,233
    12,905
    Dec 2, 2014
    Texas
    If it's at the dashboard, could be the air control valve behind the dash. A pleasure to access.
  7. rollin coal
    rollin coal Road Train Member
    13,083
    25,868
    Mar 29, 2008
    TN
    That's what I was thinking maybe, they do wear out eventually, but now I'm wondering if it's not a copperhead lol. They're real easy to access in a KW just 4 screws and you have access.
  8. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I heard the air coming from the dash one time, so I replaced the dash valve. still heard the air rushing somewhere. I forgot what is was, but is was a air line, or brake chamber or something on the truck, the sound I heard was just the sound of air trying to keep up with the leak, but the sound was not where the leak was.
