Can I do that without a broker? This is my own equipment I just need a truck to hook up to my trailer and take it half an hour to the job site.
I'm not looking for any specific trucks and not on here trying to find someone to do that, I'm just trying to figure that when we get to that point if I need a broker or if there's any other legal thing that I need to be able to do that.
I'm wondering also if I found a local owner operator that wanted to make extra money how I would do that as far as paperwork and being in compliance?
Hiring a truck to move my trailer
Discussion in 'Ask An Owner Operator' started by Dino soar, Aug 30, 2023.
Page 1 of 5
Call a heavy tow company
cke, 86scotty, rollin coal and 7 others Thank this. -
Uber has a freight board you can post to. Those fellas will have all the correct paperwork usually, though make sure to check it and call to make sure they actully have insurance ect and you will need to have tags for the equipment and the equipment in legal working order. Ive used them and temp tags to move a couple storage trailers about 60 miles and it was fairly simple and affordable.
Otherwise a wrecker or tow company can do it for a couple hundred bucks usually and will be the safest and most legal bet. Their insurance, tags, authority ect are set up to handle just about any tow job and they will know what they need on your end to do so legally and safely. They cost more but are also far more likely to get your stuff there without large fines or breaking stuff. -
Thank you for the replies.
The thing is that it may be an ongoing thing.
The situation is my brother has a farm and the truck will probably be tagged with Farm tags and we have each have our own construction equipment and we have things that we do on our own properties and for our family.
At some point we are going to go out and start doing a very small amount of Excavating, since both of us are semi-retired and we just want to go to work basically to do something and make some money with our own equipment.
So for the jobs that we would do, we would need someone to hook up to our trailer and just move it to the job site.
I don't know how big the jobs are we're going to do they might be a couple days each or maybe more I don't know but it's something definitely part-time we want to do definitely nowhere near a full-time thing.
I definitely have zero intention of hiring a driver, so I figured if it was brokered or something along those lines it would be a one-way trip for a local truck so I would imagine that wouldn't be too expensive.
I just want to make sure whatever that we would do that I'm in compliance.Siinman Thanks this. -
Probably be just as cheap and less aggravation to just hire somebody to move your equipment, forget about using your trailer.
I've been in your shoes, running a small excavation company. While you'll probably be money ahead to just hire somebody, scheduling is rough. You get a job, the customer wants it done right now, and your hauling guy can't get to moving your equipment in a timely manner. Personally, if I were in your shoes and already had a truck and trailer, I'd just get the proper tags and insurance and deal with it myself, well honestly I'd probably just bootleg on farm tags if just short hauls and not very often. Of course everything is State dependent, but in TN it's not that much more money for commercial plates and insurance over farm plates. If I couldn't move it myself or find a good local guy to move the equipment for me, I'd just scrap the whole idea. -
First thought, just hire a local company to move your trailer when you need it moved. You don’t need a broker or a contract, have them move your trailer COD.
Second thought, have you check into setting your truck up intrastate so you can use it when you want and for what you want? I understand wanting to do the farm tag thing, but if you’re paying a few hundred dollars or more every time your trailer needs moved then figuring out how to use the truck you already have could be a viable option. I know I wouldn’t have part of a day invested into something for less than $500 at least, so what’s that? 6-8 trailer moves may cover your tags and insurance. -
@Ruthless suggestion seems to make the most sense - call a tow truck to move it. You can call anytime, it's legal and it is probably someone you know. -
No broker is required if you can find a company that will move it for you directly that is legal. If you choose to use a local owner operator make sure they have their own insurance and authority and that their insurance will cover trailer interchange and haulaway type services. The motor carrier would be responsible for the trailer, load and legal compliance so you don't have anything to worry about regarding compliance only being covered in case they wreck your trailer or damage your machine. If they are not properly insured or have proper authority to operate and cause damage then you could be responsible for the damage, which could be expensive if it were a bridge strike or something similar.
The suggestion to call a local tow company is probably the easiest way to find a truck on-demand and not needing a long lead time to coordinate availability. -
@brian991219
What can I use to farm tags for? I can't use that to move Excavating equipment from the farm to an Excavating job right?
See it's a nice idea to call the local tow company or call a trucking company that has a low bed, but they're going to charge $150 an hour from the time they leave their yard until they get to the farm, then they're going to charge however long to get hooked up for the machine and then they're going to charge whatever time it takes to deliver that machine to drive there break the gooseneck down unloaded and then they're going to charge $150 an hour as far as I know until they go back to their yard.
That's a lot of money.
Not trying to pick from the mouths of hungry owner operators, but if I find a local owner operator that wants to do a local short haul, that $750 Bill turns into a $200 to $300 bill, if that.
For me to not worry about any compliance or any legal issues, I can eat a couple hundred dollars on an Excavating job, that's not a big deal.Siinman Thanks this.
Page 1 of 5
