High torque gear reduction starter for older Cummins and Cat
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Jan 13, 2022.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,229
    1,633
    Dec 4, 2019
    Wondering if any of y’all have replaced the original Delco starters, on 855 Cummins/N14’s and 3406 Cats, with the higher torque gear reduction starters?
  3. blairandgretchen
    13,225
    70,373
    Dec 9, 2011
    South west Missouri
    I did, on both the S60 and N14. Mechanic likes it because they're lighter. Spins faster, starts better IMO.
  4. Oxbow
    Oxbow Road Train Member
    12,465
    127,996
    Nov 24, 2015
    I did on a 2000 with a C15, and will likely do so as needed on our 89s. It takes a while to get used to the different sound of them, but I haven't had any issues.
  5. jamespmack
    213,427
    Money well spent on my Series 60.
  6. Shawn2130
    Shawn2130 Heavy Load Member
    894
    1,892
    Sep 20, 2015
    Ontario
    I’ve installed two high speed starters on two Cats. A 1998 and 2005.
    They’re lightweight and easy to install.
    No more laying on creeper with starter sitting on my chest then hoofing it up or worrying about dropping.
    We still have some trucks like a 2008 C13 that use those heavy starters.
  7. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    The best thing you can do it is to replace that heavy starter with a higher torque gear reduction starter. Not only is it lighter to put on but the bolts are easier to get to as well.
    Roger McG, jamespmack, Oxbow and 2 others Thank this.
  8. Last Call
    Last Call Road Train Member
    7,568
    45,898
    Mar 15, 2021
    I switch both my 3406b's to gear reduction... best thing I ever did
  9. mile marker 27
    1,229
    1,633
    Dec 4, 2019
    Man, it’s like you’ve been spying on me, cause that was me yesterday!!!
    Shawn2130 Thanks this.
  10. mile marker 27
    1,229
    1,633
    Dec 4, 2019
    What brand of starter did you put on?
  11. MM71
    MM71 Heavy Load Member
    758
    987
    Jun 28, 2008
    AZ
    Mitsubishi
    mile marker 27 and Shawn2130 Thank this.
