High rpms during extended idling.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Lonewolf2000, Oct 1, 2018.
  1. Lonewolf2000
    Lonewolf2000 Medium Load Member
    310
    322
    Nov 5, 2017
    New York
    From time to time while parked idling for a couple hours or more my rpms go from the normal 500 to 1000. This has happened with my previous trucks as well as my present one. One time when it happened with a previous truck it needed a def regeneration. That is not the case with my current truck. I usually shut the truck off than start it back back up in an hour which seems to cure it. I just get nervous when it idles high as I don’t want anything bad to happen. Is high rpms during idling anything to be concerned about?.
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    Are you sure its not trying to do a regen for the DPF? What engine do you have?
  4. AModelCat
    154,260
    Its probably trying to do a regen. If you are continually interrupting the regen you are going to give yourself major headaches in the future.
    1000 RPM isn't anything to be concerned about if the ECM is commanding it for a legitimate reason like a regen or to keep engine temperatures up in a specific range. I mean it probably spins over at 1,400 or more driving down the road with no problems.
    Jazz1, not4hire and Oldironfan Thank this.
  5. Diesel Dave
    8,520
    23,433
    Jan 20, 2010
    Hesperia, Ca.
    I keep up my Cat engine rpms until my oil pressure is at 60. Cat recommends it.
    not4hire Thanks this.
  6. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    No diesel should be extended idle under 1000 rpm.
  7. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    If the truck is increasing idle on its own I would leave it alone.
    In older diesels it was necessary to increase idle to more efficiently burn the fuel and avoid "slobbering" and cylinder wash-down. That is not as much of an issue with newer engines, but extended low-speed idling should be avoided.
    In addition to @Diesel Dave's advice, I would do as Cummins recommends:
    • When idling is necessary to maintain cab/bunk compartment temperatures, select the lowest idle speed possible to maintain cab heat.
    • Select the lowest idle speed possible to maintain engine temperature of 140* F in winter operation.
    bullhaulerswife Thanks this.
  8. Lonewolf2000
    310
    322
    Nov 5, 2017
    New York
    Volvo D13. The information display says no regeneration needed.
  9. Oldironfan
    5,777
    5,541
    May 22, 2017
    A D13 in a kw T680?
    :confused:
  10. Lonewolf2000
    310
    322
    Nov 5, 2017
    New York
    No a d13 in a Volvo,don’t mind the avatar,
    I’m just like the t680.
  11. Lonewolf2000
    310
    322
    Nov 5, 2017
    New York
    The rpms returned to normal go figure.
