Anyone run one?, if so, what kind?, how much?, etc...
Thinking about moving up to an 8 pill amp, might need to upgrade alt. also. Thanks
High output alternators
Discussion in 'CB Radio Forum' started by BigRigRob, Nov 4, 2010.
Go to the manufacturer of the truck, Freightliner, KW, Pete dealer parts dept, give 'em your vin and they can let you know everything that will fit on your truck. Of course you can fit a locomotive alternator or tug boat altenator, but it would require custom fabrication
Another Canadian driver Thanks this. -
My local shop was telling me about some very high output alternators that they use on ambulances, and they cost about 3 times what a standard one does!
Another Canadian driver and KB3MMX Thank this. -
I dont think you need a bigger alt. for an 8 pill
James3505 is right, you could probably just add 4 more batteries and be good.
Thanks for the replys y'all.
I am in orientation with a hand that owns an alternator rebuilding business in Alabama with his 2 brothers. We talked about how chicken lights and big radios affect alternators while watching the ball game yesterday. He said if you get 6 months with an alternator while running a bunch of lights and big radio then you're doing good. He said go LED lights and then have no problems...
If your thinking of a 8-pill...Best bet would either also get a Motor Maul, (and keep just your regular alternator you have now, plus 2 more battery's) or add a second alternator...
You could go with a larger alternator if you can find one that has enough out-put to keep up with the 8 pill and all the lights on the truck plus you would also need a driver for the 8-pill, so your probably looking at something like a 300+AMP alternator...Problem with these, is they don't have much out-put amps at lower RPM's. And they get real HOT. Real Fast!
Most 8-pill's need 160-180 AMP's to run.
Now you can get away with your stock alternator and a few more battery's and run the 8-pill...I seen guys that do it. But for every battery you add, your alternator will need to provide about 20 to 25 amps to keep each battery charged. And at the end of the day, your asking allot out of that alternator to keep the battery's and Amp happy!
In other words...Eventually, that stock alternator is going to have a major melt-down....Been there...Done that!
Here is my alternator set-up in my Suburban...3 220 amp alternators that power my 16 pill and 2x4 driver box's.
Another Canadian driver and BigRigRob Thank this. -
Dang, what a set-up Jessie. Thanks for your input. I cought you on the radio a few weeks ago down on I-20 by the 175 split, you just got home, did'nt talk long. See ya at CBRT.
Oh yeah, as for a driver, I'm thinking about sending my Connex 43-300 to Mike out in Az. and have him mate it with a Dave Made. He already has my RCI-63FFC2, have to wait for that one to get finished first, what do you think?
