High oil pressure 2006 D12.
Discussion in 'Volvo Forum' started by Bubaka, Jan 2, 2013.
  1. Bubaka
    Bubaka Bobtail Member
    19
    4
    Apr 6, 2009
    Albany, ny
    After being out of truck for about a week I have started my truck,2006 Volvo with Volvo ved12 engine, today and have this high oil pressure reading on gauge ~100. It was normal before the break at 60. I thought that it is high because of cold, but after making a trip to pickup place it still shows 100psi. The truck is running ok and there are no fault messages. The oil level looks normal too. Last oil change was done about 5000 miles. What could be the cause and how save is to run with this oil pressure in engine?
  3. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    I would venture it's a sending unit/gauge if it hasn't moved. If a filter collapsed it would be on the low side.
  4. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    how cold was it, how far to the pickup, and did you have a winter front ? jon
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    usually bad oil pressure sender. Broken diaphragm and it reads 7 BAR any way
  6. Bubaka
    19
    4
    Apr 6, 2009
    Albany, ny
    Thanks for your replys. I have just made a 1500 miles trip with the truck, so far so good. So guess I will be replacing the sensor then. I'll post what will happen.
  7. Bubaka
    19
    4
    Apr 6, 2009
    Albany, ny
    Finally got to replace the censor. I was told the wiring was bad and somehow it broke the censor. The pressure is showing ~60 again.
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    you can use fuel pressure sensor... just swap sensors and keep driving, becouse w/o fuel pressure monitoring nothing bad may happen, but w/o engine protection by oil pressure.... ouh, knock--- knock)))
  9. Bubaka
    19
    4
    Apr 6, 2009
    Albany, ny
    Good to know Pablo-UA. Next time I will keep it in mind.
  10. maxicruise
    maxicruise Light Load Member
    58
    19
    Aug 11, 2010
    Illinois
    Just turn the key to the on position with the engine off and see if the oil pressure gauge goes up. It will usually read around 30 to 40 lbs when the sensor has gone bad. Have seen more of them reading 30 or so lbs higher than no reading at all.
  11. Bubaka
    19
    4
    Apr 6, 2009
    Albany, ny
    Maxicruise, thanks for the reply. The issue is resolved, I have replaced the sensor. Everything is alright for now.
