High coolant reservoir pressure
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jrairman1, Aug 9, 2023.
  1. Jrairman1
    Jrairman1 Bobtail Member
    13
    8
    Aug 9, 2023
    Hello, I need some help diagnosing a high resevoir pressure situation. 2015 cascadia dd13, 700k miles, pulling trailer I get the resevoir discharge hose spitting out coolant, only on hard pull or loaded trailer, never idling, replaced thermostat, flushed radiator, eliminated egr cooler as problem, eliminated air compressor as problem, did block test with blue liquid, no change in color even after half hour or bubbling, did bottle test start generating bubbles after thermostat opens at 170 degrees, no overheat condition highest its gotten is 225 on the gauge, no white smoke, clean oil, what else can I check to rule out head or head gasket, no fuel in coolant so don't think it's injector cups either...I'm at a loss, don't want to start removing the head only to find out nothing wrong, for nothing. Bought deleted, has egr pipe plugged at intake and also plugged from exhaust manifold to egr cooler on both connections, so no pressure at all at egr cooler and it's bone dry inside, tested fan clutch operation seems fine....any help would be greatly appreciated.
    Reason for edit: Mis spelling
  3. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,393
    Mar 18, 2021
    St Malo mb
    You change the cap it weakens over time
  4. Jrairman1
    13
    8
    Aug 9, 2023
    Yes, forgot to mention, replaced resovoir, whole thing brand new
    Rideandrepair and Magoo1968 Thank this.
  5. zinita17601
    zinita17601 Road Train Member
    1,317
    1,603
    Aug 19, 2010
    lancaster pa
    Oil cooler?
  6. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    I've tried that fluid in a truck with a known bad head gasket and it didn't change...
    AModelCat, BoxCarKidd and Last Call Thank this.
  7. JB7
    JB7 Medium Load Member
    643
    894
    Dec 13, 2022
    Laurel, MD
    Last Call and RubyEagle Thank this.
  8. Antinomian
    Antinomian Road Train Member
    2,076
    3,241
    Feb 17, 2013
    Are you losing coolant?
  9. Jrairman1
    13
    8
    Aug 9, 2023
    I loose coolant thru discharge hose when pressure exceeds the 15 psi cap, no other leaks,
  10. Jrairman1
    13
    8
    Aug 9, 2023
  11. Jrairman1
    13
    8
    Aug 9, 2023
    Great video, thanks
