Hey guys what daycab is best for gravel hauling and has most clearance of the ground
Discussion in 'Questions From New Drivers' started by The_firm, Dec 2, 2019.
  1. The_firm
    The_firm Bobtail Member
    44
    15
    Nov 12, 2019
  3. bigkev1115
    bigkev1115 Road Train Member
    2,363
    3,609
    Oct 23, 2009
    Alexandria, AL
    You usually see a Pete, KW, or Mack doing that kind of work
    D.Tibbitt Thanks this.
  4. rbrtwbstr
    rbrtwbstr Road Train Member
    3,329
    7,589
    Jul 11, 2012
    in the bush somewhere
    There's no correct answer. It's like the Ford vs. Chevy argument. They all can be the 'best' if they're spec'd correctly.
    Some will argue to the death over a Pete, others a Western Star, still others a Mack. All of them are solid trucks. Even Freightliner can be a good setup, I see lots of them pulling dump trailers.
    Now for ground clearance? I've yet to see a truck with as much ground clearance as a Western Star. Our mechanic loves ours. He's got a beer belly that rivals Santa Claus, and he can fit under them with no issue.
    Jrdude5 Thanks this.
  5. Mattmanstroked
    Mattmanstroked Light Load Member
    185
    278
    Nov 24, 2019
    Mack CH model with 11R rubber and Mack rear ends.
    My opinion
  6. The_firm
    44
    15
    Nov 12, 2019
    Is it expensive to put a wet kit on a truck as well as hydraulics for that line of work.
  7. TRS Group
    TRS Group Light Load Member
    93
    117
    Sep 24, 2018
    Depends on where you go. I known places to charge as much as $2000 and other places for as low as $800. Go with a Muncie pump and pto. They are a bit pricey but well worth the investment
  8. The_firm
    44
    15
    Nov 12, 2019
    Where are they located and do they do both or just one
  9. TRS Group
    93
    117
    Sep 24, 2018
    To your original question, I was a dump owner operator for 6 years in chicago, I ran with a Mack CHN613 427 and had no problem pulling 73,000 on a 22 foot dump trailer. Up inclines or even backing up inclines that truck was a beast
  10. TRS Group
    93
    117
    Sep 24, 2018
    In McCook IL and the mechanic I know will put PTO in the cab if you want it thete
  11. TRS Group
    93
    117
    Sep 24, 2018
    You need back for this business, and one with over 400 hp
