hello, I have a external swr meter and just bought a new radio but before i hook it up i wanted to make sure my swrs were down and of course cant find my jumper. i do have a 9 foot coax though will this be ok or do i gotta use a 3 foot one to be acurate? thanks
hey does the "jumper wire" between my swr meter and radio need to be a certain length
Discussion in 'CB Radio Forum' started by fgb3, Nov 11, 2011.
Just going between the radio and a meter, it really won't make much difference one way or another...3' intervals (3', 6', 9' etc...) is what most will say use, but I've never ran into a problem using whatever length it takes to get from point A, to point B... Because once you get everything hooked-up, your going to adjust the stinger on the antenna to tune the SWR anyway.
Now this is if your planning on leaving the meter in-line, and not take it back off.
Now if your going to be installing a Amp, or using a 102" Whip (which is not adjustable) then the 3' rule may well apply... -
no given length even at VHF
Yeah ok that was what I thought. Now one more question,I have almost 3s on 1,20nand 40. I have one large ground wire (almost as big around as the coax) hooked through one of the four bolts on my mount. The other end goes right into a hole in the frame where I already took the paint off just to be sure. Still almost 3s on my meter any suggestions? Wire to big or need more than one or what. Its in a brand new Cascadia and I'm planning on putting a new general lee in but its staying in the box til I figure this one out. Thank for any suggestions
fgb3 Thanks this.
I'm running a wilson 5000 off a mount I made on the bottom of the mirror. I just saw one almost like the one I made but its stainless steel I think I'm gonna try that. I had ok ground with just 1 wire to the bolt the batteries are grounded with before on 2009 but this new one just won't work. I'm not sure if antenna is to close to truck or what but ill figure something out before I put my new one in here that's for sure. Thanks for the tips maybe ill try bonding see what that does. I noticed that wy buddy was standing next to the truck on the ground. He grabbed the black part and swrs went to 1.3lol I just gotta talk him into running next to me. Thanks again
I've been using the standard 18' piece of coax to the antenna and any jumpers used to meters or amp have been 3'. Been using this for 30-years now, without an issue.
There is loss but on a mobile, you can't even tell the difference. I prefer to use just enough because I don't have anymore room for chords. So I use 3ft jumpers and 9 and 12ft runs. With multiple radios and such, it gets cluddered pretty fast.
I'm willing to bet your antenna mount is not getting the ground it needs...If it's mounted on the mirror bracket that wouldn't surprise me, some of these new mirror brackets just don't get a good ground...You can try running ground straps off the mirror bracket to a good grounding point like the firewall or frame and see if that helps.
Using old coax like Mike5511 was saying works just fine, but usually what I do is strip off the outer jacket of the coax, then pull the center conductor wire out, then flatten the braid and put a little solder on the ends, then attach that using self tapping screws...But either way would work.
On my work van I originally wanted to mount my antenna on the mirror brackets, but no mater what I tried I could never get a decent ground...Ended up fabricating a fender mount under the hood and mounted the antenna that way, and it worked perfect!
WA4GCH Thanks this.
