Hesitation and jerking when shifting gears
Discussion in 'Freightliner Forum' started by Chemical-Mover, Aug 8, 2015.
  1. Chemical-Mover
    Chemical-Mover Bobtail Member
    Probably not the best title for a post. The issue our truck is experiencing is when shifting gears, there is a "rough jerk" as reported by a couple of my drivers. These are experienced drivers so they do know how to drive. One of the drivers, who has some mechanical skills said that the drive shaft can be rotated by hand. What I am wondering is if the jerking could be caused by a bad u-joint? Any help would be appreciated. Thanks
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    CK. the ft. rear end by draining some gear oil out an look at it spread out on white paper or sent it off for ani. some turn in drive shaft is ok but not much?
  4. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Truck and engine make and year?
  5. Mr.X
    Mr.X Heavy Load Member
    737
    596
    Oct 31, 2013
    Spokane, WA
    A ujoint that loose would make a heck of a vibration going down the road. I agree with baha, check out that front drive axle. They used to have magnetic drain plugs, dont know if they got cheap and didnt use them on newer trucks?
    With that much slop, you should find a bunch of scrap metal hanging off that plug! Analyze it with your eyes, lol.
  6. AModelCat
    154,281
    There will always be some rotational play in the driveline. I would check both diffs as they both receive 50/50 split of the power. Internal damage to either one could cause excessive play. It wouldn't hurt to check for excessive rotational play in the slip yokes/u-joints and check for metal in the transmission as well. There are a lot of moving/wearable parts between the flywheel and the hubs. If the truck has high miles on original components it could even been a little bit of wear in everything contributing to a large amount of slop over the whole drivetrain.
  7. Edstheman
    Edstheman Bobtail Member
    You might have bad fifth wheel side pins.
