Just purchased a dump trailer that is a spread axle. Most I look at had broken frames around the front axle. I see Hendrickson has a lift axle kit for sale. Just wondering if anyone has experience with them. Are they worth it? Other/better brands? This trailer is in great shape and I would rather spend a few bucks to get the axle up since we go into tighter places than break it up.
Hendrickson lift axle kit
Discussion in 'Ask An Owner Operator' started by GFTLLC, Feb 11, 2022.
Page 1 of 3
Instead of a lift on the front axle just put a dump valve on the back axle.
krupa530, God prefers Diesels and GFTLLC Thank this. -
OLDSKOOLERnWV Thanks this.
That dump axle option will give you a better turning radius on the rear, plus save wear / tear on the tires. Now I’m not familiar with the setup you have on the dump trailer, are they independent?
I use to haul flat glass out of Bridgeport, WV many moons ago. That dump axle made maneuvering a 48x102 a lot nicer in tight areas…..God prefers Diesels and GFTLLC Thank this. -
As far as dumping the rear axle I considered adding a switch to do that also but I hear in some places that may be frowned upon having switches for each axle. I know many who have done it but I like to keep a clean nose if that makes any sense.OLDSKOOLERnWV Thanks this. -
I use to haul train wheels / axles with a 1988 Cabover Kenworth that still smelled new, because it was. We had dumps on the truck and trailer. Dump the tractor when loading so it was easier to roll the wheels to the front, and dump the trailer when unloading to make it easier to roll them to the rear.
Lifting the front axle is pretty common when running empty on many trailers. There should be no issue in that at all, unless something has changed….?GFTLLC Thanks this. -
God prefers Diesels, GFTLLC and OLDSKOOLERnWV Thank this.
It’s something to watch for, but shouldn’t be all that much of a problem. Turn signals, and mirrors, and take your time…..God prefers Diesels and GFTLLC Thank this. -
Page 1 of 3
