Hendrickson AR2 Conversion
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Oxbow, Feb 11, 2017.
  1. Oxbow
    Oxbow Road Train Member
    12,448
    127,833
    Nov 24, 2015
    I currently have Hendrickson RS (Rubber load cushion) walking beam suspension on an 89 Pete 378 that we use pulling a 50 ton lowboy. It rides terrible empty, but it is real nice with about 50K on the drivers, and I like the walking beam for off road construction sites.
    I am considering a conversion kit that Hendrickson has (AR2 air over walking beam). This conversion utilizes the existing walking beam, but replaces everything above that with an air suspension utilizing two bags per side. It appears as if it would be fairly straightforward to do the conversion. The existing longitudinal torque rods are used, but we would need to add a transverse torque rod for each axle, which would require drilling/mounting a frame bracket and welding a bracket to each axle housing. I would also re-bush the walking beam when doing the conversion.
    Hendrickson has an Application Approval Request Form that I am filling out to obtain the correct conversion kit, at which time I need to contact a Hendrickson Dealer to obtain pricing.
    My question is: Does anyone have any experience with this conversion, and if so would you recommend it? I am curious as to how much improvement there is in the ride characteristics.
    Here is a link to a youtube video on the conversion kit:
    SAR and snowman_w900 Thank this.
  3. T800H
    T800H Medium Load Member
    608
    295
    Apr 2, 2010
    The Keys
    did you do it?
    Oxbow and snowman_w900 Thank this.
  4. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    I have always wondered about this kit also.
    Oxbow Thanks this.
  5. Oxbow
    12,448
    127,833
    Nov 24, 2015
    Hendrickson got back to me and approved my application, but said it would be five weeks before they send me the kit number. After that I guess I go to a local Hendrickson dealer with the kit number and obtain pricing/order the kit. I don't know how long it will be before I can actually get it in my position, if the price doesn't scare me too much that is. Anybody make a guess on cost? All of 5k I would guess.
  6. dirthaller
    dirthaller Road Train Member
    1,012
    11,790
    Sep 22, 2011
    Coloratah
    A local suspension dealer here in SLC told me $12,000 installed with your "R" series beams. $18,000 installed w/out existing "R" series beams. Wonder how much of that is labor/parts.
    Oxbow, snowman_w900 and SAR Thank this.
  7. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    Ohhhhh...dam, i think id just go find you a good neway air ride cut off at that point @Oxbow, what say you?
    Oxbow and SAR Thank this.
  8. dirthaller
    1,012
    11,790
    Sep 22, 2011
    Coloratah
    Neway is a heavy duty suspension for sure, but they don't "walk".......worth a tinkers dam.
    Better have full locking diffs with Neway!
    wore out, Oxbow and snowman_w900 Thank this.
  9. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    Yeah thats true. Under a dump truck or something thats going off road alot, i like a walking beam.
    As far as having one under a semi truck doing more on road than off, the walking beam is just to rough for my taste. Guess it depends on what your doing with the truck is the thing
  10. Oxbow
    12,448
    127,833
    Nov 24, 2015
    That's a bit more than I had in mind. We'll have to see what the kit costs without labor.
    We don't spend all the time off road, but most every load gets picked up or delivered on a construction site. I really like our rubber pad suspension for that, and it rides OK when loaded, but empty on a washboard gravel road is brutal.
    I would imagine that we would have at least 12 grand into getting a Neway cutoff installed, as I wouldn't have the confidence to do that work myself. We have d461p 2 speed rears that I want to keep, so there would be a lot of work changing out the axle mounts to a different suspension, which is why this conversion is appealing.
    We'll see what the price of the kit comes in at and go from there.
    We only run around 20 thousand miles a year, so I can't justify too much into this. I am rebuilding the engine and updating the RTOF 15618 to 18918, and would love to do the rear suspension at the same time, but we'll have to wait and see. It's hard to put 30K into a 15K truck, but it will last us forever, and I like it.
    Reason for edit: Added info.
  11. T800H
    608
    295
    Apr 2, 2010
    The Keys
    I have always been an air ride guy on all my trucks, right now I have a Hendrickson Primaax and love it (dump truck) .
    but I took a ride with a guy that had a RT walking beam and it was the best riding truck with non air ride, very soft and quite loaded and empty, I was very surprised, very close to air ride, but I've always been curious about the air ride walking beam conversion best of both worlds.
    my price guess is probably around $5k for the kit, I would buy at around that price and install it at a local shop but $12k to $18k sound like a lot of money specially if you only run 20k a year.
