We are working hauling clay with my kenworth tri axle dump truck. Grossing 80 to 85k. When i back down under the excavator i sink a little as we are driving on very soft ground. When loaded the super tens low gear will not pull out by any means it feels like you put your truck in 5th gear with the parking brakes on and let the clutch out. What are my options to get this truck to perform the task. Is it my rear ratio or trans? What trans options do i have that will swap easily with the super 10? How well does a 8ll perform will the ll pull out under these condidtions? Any help is great thanx!
Helpp super ten will not pull out loaded!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JakeBrakeChampion, Jun 16, 2011.
8 LL is a great tranny for that use. i swapped a 13 out for one. driveshaft work, cooler lines to tranny, lucky if you find someone to take a 10 core in for anything other than a 10.good luck to you. johnny
The 8LL is good for that but thats about it imo. I drove 1 for awhile and did not like it. The gears are spaced to far apart on the top side. It seemed like when you were in 7th and trying to go up that you could wind it all the way up but 8th would cause it to fall on its face as the rpms dropped off to far. A 15 or 18 would be my choice.
What is your rear end ratio? I have a feeling that if your truck has a super 10 it might have been a tractor converted to a dump. It probably has very high rears and thats might be half you problem.JakeBrakeChampion Thanks this. -
i have a super 10 and haul heavy all the time load in the feilds pulls out just fine but i do have a MR haney tune on my c15 so 60 or even 80 in the box is no problem i have 3:55 gears if that helps
I think I would have to vote for the 18 speed. Depending on what you have for power in front of the trans., I think the 18 will typically stand more torque than the average 8LL. Most times you never need all of the different ratios, but there are times when that half a gear comes in handy.
The 8LL would be my second choice, which is also a very good option. A little cheaper to purchase, and very simple to operate.
Find out for sure what you have for rears because swapping them may also be an option.
I would recommend calling a reputable drive train dealer for starters. I use Camerotas here in the north east and they have been great in helping me with all of my swaps. I tell them what I have (engine, trans., and rears) and then what I am looking to get for an end result, and they can recommend a combo that fits my needs. This route is more expensive than just finding any old tranny or set of rears for sale, but the expert advice, fast service, and warranty they provide are well worth it to me.
Hope this helps and good luck!JakeBrakeChampion Thanks this. -
But you can shift them in a row. If it can be done with a 8LL I never figured it out. Maybe the gap was to big form 6 to 7 I dont remember it was along time ago. I just remember not liking it. I owned a 15 spd and I liked it alot. The 15spd also has 2 good reverse gears. -
