Good morning. My boss just bought a trailer from a guy over in Georgia. It is a 2020 40' Diamond C fmax212 with a Ridewell front lift axle and air suspension. I'm going to go pick it up next week, but I wanted to make sure I understood how to run the lift axle.
Is it as easy as kicking the compressors on and go ahead and lift the front axle and go when empty?
Are you supposed to lift the front axle when back into a spot, even if loaded?
Is there a way to dump the air to both axles to load lowered down?
Are there any other adjustments in ride height? Or is it all or nothing? You are either running with the lift axle all the way up or all the way down?
Appreciate any info! Thanks.
Help with lift axle gooseneck operation
Discussion in 'Questions From New Drivers' started by KINGPENM3, Oct 24, 2023.
