Help with dual leveling valve system
Discussion in 'Trucks [ Eighteen Wheelers ]' started by kwforage, Apr 30, 2009.
  1. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    I am changing my 8 bag Air Glide 100 to a dual leveling valve setup. I have a straight truck so the box makes it a real P.I.T.A to trace the lines, otherwise I would just look to see how it is setup now. I 've drawen how I think it should be, but I am not certain. Can some one please tell me if this looks right, or am I way off? Mainly I am wondering about my connections at the dump valve.
  3. MedicineMan
    MedicineMan Road Train Member
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    most people go from dual valve to a single because the dual systems are a pain in the *** to keep in adjustment
  4. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    Assuming the swithes to the left of your diagram are the electric switches, yeah that will work. You could also run two lines out of your dump valve, one the the front axle and the other to the back. Or better yet, after the dump valve, put in a quick release to T off to the front and back.
    If you wanted to stay with one leveler just T it off and add the dump valves after the T. Do not buy the cheap plastic POS levelers! They are a PIA to adjust. Buy the good metal ones, they have a screw for fine adjustments.
    kwforage Thanks this.
  5. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Your schematic looks good. When you adjust dual system valves, you have to adjust one side at a time. Start with adjusting one side to the proper ride height with the other side disconnected. Then repeat with the other with the first side disconnected. Always adjust to the proper height on the up-travel with the brakes released and wheel blocked.
    ichudov and kwforage Thank this.
  6. kwforage
    1,047
    472
    Jun 3, 2007
    Wisconsin
    Yeah, I got the metal height control valves. I see you can use them as long arm, or short arm. I would assume the short arm will be more responsive. Not sure which way I will mount those. Thanks for the help guys.
  7. cat from the valley
    cat from the valley Medium Load Member
    469
    32
    Dec 8, 2008
    jamaica
  8. kwforage
    1,047
    472
    Jun 3, 2007
    Wisconsin
    they are Haldex Cr's
  9. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Hi kwforage: I am going to take advantage of your question.... :biggrin_25519:
    Who makes the best leveling valves?
  10. crazzy448
    crazzy448 Light Load Member
    86
    6
    May 3, 2009
    panhandle wva
    I have worked with them and they can be a pain. but will help with uneven load swaying. u can just t off the dump switch no need for 2 switches. i have used this set up on rv to help with the wanderring issues.
