Help with 2015 Volvo VNL!!!! Comfort ride!!!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Rocky The Expert, Dec 19, 2019.
  1. Rocky The Expert
    Rocky The Expert Bobtail Member
    7
    Dec 19, 2019
    Hello everyone my name is Rocko. I purchased a 2015 Volvo VNL 670 over a year n half ago currently sitting at 578k I have done some minor upgrades nothing over the top. I had a few mechanical replacement but if you guys want to find out more about my breakdowns or just repairs just ask!!(didn’t have too many just a few) This post I’m just trying to get more info on better ride quality. I have upgraded all my shocks to start this better, smoother ride quality modification, I’ve gone with the Fox shocks 2.5 mono tube premium line shocks all the way round the truck(yeah I know they’re pricey but eehhhh what the heck) I have noticed the difference as far a stability but smooth ride quality not so much on the bobtailing side only when loaded with at least a trailer the ride smooths out a bit but with a trailer and a load in it then is when the magic of the shocks works but I’m trying to get it to where it’s smooth loaded and in bobtailing because i bobtail quite often. I’m thinking of replacing all my air bags on the truck and for cab I’m going replace shocks and air bags. Any suggestions from my fellow Volvo operators out there?? #volvogang
  3. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    A common overlooked part needing replacement on a Volvo is the front cab bushings.
    Dino soar, Bakerman and Socal Xpress Thank this.
  4. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    Keep us posted with your search and progress.
  5. Rocky The Expert
    7
    Dec 19, 2019
    Front cab? Hmm I’ll ask shop when I bring her in next time thanks for your suggestions
  6. Rocky The Expert
    7
    Dec 19, 2019
    Yup I’ll do my best just trying to get that ultimate smooth comforting ride
  7. glmi1
    glmi1 Bobtail Member
    6
    May 15, 2014
    Did you ever end up replacing the front cab bushings or figure out the issue with the ride quality? I have similar problem with a 2012 VNM630 with newer shocks and front springs but still rides super rough.
  8. AModelCat
    154,265
    Changing air bags will make zero difference in ride quality. Its just a bag of air. Putting a new rubber bag of air in place of a used rubber bag of air won't change anything.
  9. TheLoadOut
    TheLoadOut Road Train Member
    2,138
    10,048
    Nov 6, 2019
    Check the leveling valves as well. There's one on the rear frame, and one directly under the back of the sleeper for the cab, right in the middle. A lot of times it becomes disconnected because the little ball it clicks into wears out and the arm falls out. That will definitely change your ride as the cab isn't floating on air.
  10. Rocky The Expert
    7
    Dec 19, 2019
    Thanks got it will check that !!
    TheLoadOut Thanks this.
