HELP! TRUCK ONLY STARTS WITH STARTER FLUID
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Supplychain2019, Nov 29, 2021.
  1. Supplychain2019
    Supplychain2019 Bobtail Member
    4
    4
    Nov 29, 2021
    Hi first time posting here since I can’t find my solution anywhere else
    I have a 2007 Freightliner Columbia with a 14L Detroit 60 series engine
    The truck was running perfectly fine until one day it would crank but would NOT start.
    Now it only starts with starter fluid. BUT once the truck has been running it starts and shuts off with no problem.
    I’ve checked / replaced
    electrical - batteries, starter, fuses, starter solenoid
    Other - Fuel/water separator and the check valve behind the engine
    and I’ve even used fuel injector cleaning fluid
    When I changed the filter of the fuel/water separator it would start but very faintly
    Now here’s the thing … I come to
    You guys because I don’t know what else to check and my mechanic is suggesting that it can be the injectors but truck runs strong once it’s on, so I’m doubting it’s the injectors
    austinmike Thanks this.
  3. Joyce's Volvo
    Joyce's Volvo Light Load Member
    96
    132
    Jun 28, 2016
    Does it smoke while cranking? No smoke means no fuel, could be fuel draining back or the fuel transfer pump could be weak. Chech fuel pressure.
    Supplychain2019 Thanks this.
  4. Supplychain2019
    4
    4
    Nov 29, 2021
    there is no smoke coming out out the exhaust while cranking… so does this mean check fuel pump and fuel lines ? Okay worth a shot I’ll check it out tomorrow and keep you posted.
    Bean Jr. Thanks this.
  5. GYPSY65
    GYPSY65 Road Train Member
    1,956
    5,263
    Nov 16, 2012
    SW FLA
    I’m not 100% positive on this but seems I’ve heard using starting fluid is a bad idea and can cause a bunch of other problems
    I know you need to do what gets it going but if what I heard is right. The sooner you fix the issue the less chance of a snowball effect
    Don379 Thanks this.
  6. Rideandrepair
    17,212
    55,865
    Aug 8, 2015
  7. mtntopbound
    mtntopbound Bobtail Member
    38
    71
    Sep 9, 2019
    Everywhere man
    A bad srs sensor will act like that, I would probably replace both srs and trs sensors at the same time. Just a guess without a scanner, but I have seen that same thing before and it was the srs.
  8. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    If the problem started around the time you changed the fuel/water separator, perhaps you have a leak at the filter?
    Rideandrepair and Supplychain2019 Thank this.
  9. Supplychain2019
    4
    4
    Nov 29, 2021
    Hi.. great suggestion. That’s exactly what I did, the fuel/water separator wasn’t installed correctly. The truck is turning on now but still turning on very weak.. going to also change the SRS & TRS sensors this weekend coming up
    blairandgretchen Thanks this.
  10. AModelCat
    154,368
    Yes its extremely hard on engines. Its like crack for an engine lol.
    Badmon and GYPSY65 Thank this.
  11. Ffx95
    Ffx95 Road Train Member
    1,368
    2,628
    May 18, 2017
    I’m not mechanic but I would guess it’s hard on diesels because of how easy it is to detonate. It burns up easier than gasoline so I would guess there’s some predetonation going on.
