help transporting a cat D6
Discussion in 'Experienced Truckers' Advice' started by tonher, Aug 13, 2011.
  1. tonher
    tonher Bobtail Member
    38
    16
    Jul 30, 2008
    Phoenix, AZ
    Hi all,
    I wanted to throw out some question to see if the more experience truckers can help me. Recently started hauling stepdeck, use to haul reefer.
    I wanted to ask if my 48 feet stepdeck trailer is legal to haul a cat D6 machine that weighs like 38,000 lbs.
    If legal will I need to get oversize permits? And where do I get the permits from? Or where can I get this information from?
    LIke I mentioned before I'm a newbe hauling stepdeck or machinery And could really use some advice from a more experience trucker.
    Also how much tiedowns a machine like this needs to be safe and legal?
    I know the tie downs must be chains.
    thanks in advance for your advice.
    be safe.
  3. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    How wide is it? If you aren't going to be over 102" wide, you aren't over-width.
    How tall is it? What is your deck height? If it won't be over 13' 6" tall while riding on your trailer, you aren't over-height.
    What's your tare weight? If the D6 is 38K, as long as your tare weight is below 42K you won't be over-weight.
    5-6 chains ought to be sufficient. Cross 'em in the front & rear to keep the equipment centered. One more across any accessory (i.e. blade, bucket, etc.). If it looks like it needs more, use more...no such thing as too much chain.
    One other consideration if using a step deck: Just because there may be a way to load the equipment onto the step at the shipper doesn't mean there will be a way to get the equipment back down to ground level at the receiver. That would be a good thing to find out BEFORE you get there...
  4. haulhand
    haulhand Road Train Member
    Another thing you should think about if your step is aluminum with an aluminum deck the tracks on a dozer or any tracked machine will straight tear the deck up if you have wood you will be fine but aluminum decking does not like tracks. Also cross chaining is by far the best but it cuts the rating of your chains in half so if you have 12000 lb rated chains they are only worth 6000 lbs so you have to use two chains. You get your permits from each state that you will be going thru or you can use a permit service. And be sure that you have oversize banners and flags before you load.
  5. southtx
    southtx Light Load Member
    55
    27
    May 22, 2011
    hondo, tx
    The rule I usually use when hauling equipment is to make sure that I put enough chains to hold 1.5 times the weight of the machine. So if your chains and booms are rated at 5500 lbs I would use 10 chains. I know that sounds like a lot, but I've never had a machine come off the trailer. Also like pedigreed bulldog said, you must have a chain over the blade and over the rippers as well. The blade and rippers must be all the way down, touching the deck. Also I was told by dot in texas that its illegal to leave the key In the machine while transporting it.
  6. tonher
    38
    16
    Jul 30, 2008
    Phoenix, AZ
    thanks all for your reply advice and support. Hauling the cat D6 will be a challenge for me being a new stepdeck guy. But I'm up for the challenge.
    This will be my first machine and hopefully not my last!
  7. Bigray
    Bigray Road Train Member
    1,135
    383
    Nov 23, 2007
    Tampa, Florida
    I use a permit service for all my os/ow loads, i receive these loads via my email then print them out.
    i would also like to suggest picking up the OS/PILOT car directory from one of the TS, it will give you traveling times allowed, escort req. light and flag req. / sizes.
  8. okiedokie
    okiedokie Road Train Member
    11,677
    84,535
    Jun 13, 2011
    PNWET
    One thing I will add is to protect your decking get some old tires to run over. Even wood decks get torn up from tracks. When you are not centered and try moving that dozer on the deck och! Get lined up before you run it up on the trailer.
  9. loudhornsrule
    loudhornsrule Light Load Member
    74
    40
    Jan 29, 2009
    north texas
    When we move our D6 20-30 miles we dont even chain it down, but your supposed to have 6 chains minimum. Those newer nice step decks are not really built for hauling dozers. You can do it , but its hard on the trailer!
  10. flatbedder
    flatbedder Medium Load Member
    482
    202
    Oct 10, 2006
    Illinois
    Thats intelligent. What if in those 20 to 30 miles it tips over on a passing car? What will you do then? :biggrin_25513:
  11. spax
    spax Medium Load Member
    361
    364
    Aug 5, 2011
    United States
    Have to get a new dozer I guess!
    Big Duker Thanks this.
