Valve is bad or at least im pretty sure it is, can someone tell me where it is and how to do it? Thanks in advance
Help replacing fuel check valve on 3406e
Discussion in 'Trucks [ Eighteen Wheelers ]' started by favored, Oct 26, 2011.
If it is the valve I believe you are looking for, it is on the bottom of the fuel block mounted behind the air compressor. If I remember correctly a 15/15 or 1 inch wrench will remove it. Ensure you have a new oring on the new check valve. Do not reuse the old oring.
10 4 thanks for the info
Got er in problem solved...wish all repairs were as quick and cheap as this one
Yes- fuel lines will collapse. The inner lining separates and pinches off the fuel flow. Good fuel lines have three layers. The inner layer separates when it gets old- and, collapses from suction.
Sometimes the fuel line connections loosen and they suck air. The most common problem is fuel cutoff valves leaking air. If you have valves that cutoff the fuel from each tank, they leak after a few years. The material used to seal the valve dries up and shrinks, letting air in under a vacuum.
If you have those fuel cutoff valves and never use them you can just replace them with fittings that have no cutoff valve in them. Easiest way to solve that problem. Fuel lines are easy to replace, and if you don't like cutoff valves or don't want them, just replace the whole length of fuel line and leave the cutoff valves out.
There's a small chance it's the fuel tank vent tubes that's causing the problem, in high dust situations the vent tubes can clog- just remove the fuel tank caps and blow the vent tubes out with compressed air.
