HELP! PTO won't disengage...2000 Freightliner Century Class
Discussion in 'Freightliner Forum' started by talltexasgal, Aug 18, 2013.
  1. talltexasgal
    talltexasgal Bobtail Member
    5
    San Antonio, TX
    Howdy! We are owner-operators hauling frac sand, and our PTO won't disengage and our mechanic doesn't know what the problem is. 2000 Freightliner Century Class with a brand new Chelsea PTO, new reman Eaton Fuller 10 speed tranny, newly rebuilt Detroit 60 engine, new clutch, new ride height control valve (with correct ride height), etc. We have been hard-down for nearly 2 months now getting all these new parts installed and still have the SAME problem as when we first broke down....the PTO won't disengage. Someone please help!
  3. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Air or mechanical engage? Get you butt under the truck and look at the lever and disengage the PTO....did it move? No? Move it by hand and be done. Fix why not like air cylinder or cable.
    Lever moves but still engaged? Throw in clucth for all actions....work? No? PTO has problem. You said it's new , take it off and get another one, this one has problems. Some units have square drive and some have hex stud for lever mount, make sure lever is turning this rod.....
    It's a real simple operation....wassup with your wrench ? He don't know this? Be sure to tell him to drain the tranny before he takes PTO off and tell driver to use clutch every time in the future. mmmm just in case.
    Later
  4. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    ck not proper gasket PTO 2 trans its easy 2 add 1 gasket drain into clean 5 gal. bucket pump back in after adding 1 gasket gear clearance amust 2 work
    chalupa Thanks this.
  5. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    Exactly what chalupa said!
    Your "mechanic" really needs to be posting here, describing the steps he has taken to see why/what is not letting the PTO disengage, none of which is described in your initial post. Simply put, it is either the related linkage parts (air/mechanical/cable) not allowing it to disengage, or the Chelsea PTO box itself (from engage/disengage lever inward) not disengaging due to internal problem. Wait... now I'm just repeating what chalupa said.
    Edit: Didn't see baha's post until now. He makes a good point & common clearance problem/remedy, which can also be detected by trying to move the PTO arm manually.
  6. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    without knowing more im thinking the backlash may not be set properly causing it to stick.
  7. talltexasgal
    5
    San Antonio, TX
    This is air engage....Chelsea PTO part #489GRAHX-A3XD. My husband is the driver, and he's broke down at the oil well right now waiting on the tow truck, and I'm home trying to figure out why we had this problem with the original PTO (unknown brand), and now with this new Chelsea PTO. Same problem; brand new PTO. Our mechanic seems to be knowledgable, but we don't want to keep replacing parts and still have the same problem! I was hoping this forum would give me some wisdom as to what the underlying problem actually is. Thanks!
    EDIT: The PTO worked correctly twice at the mechanic's shop before my husband went back out on the road...mechanic tested it, and my husband tested it. Got loaded, unloaded, then PTO wouldn't disengage. We have a Gardner-Denver blower.
  8. chalupa
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Agin its simple ops, gear slides back and forth by lever / piston actuation and meshes with gear to drive shaft. Shaft or lever not moving or PTO not shimmed correctly etc.
    Get some more data from hub like method used to engage....and maybe get new wrench.....
    JMO
  9. KW Cajun
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    Hope they can get it troubleshooted & the problem fixed. Hopefully a simple repair, at minimal costs. Sounds like you both deserve a BIG break.
    Your mechanic should know, but if he/they remove the air linkage connection to the PTO engage/disengage lever (under truck, on PTO case) that will isolate the problem into 2 main sections for troubleshooting (air "shift" linkage parts solely vs PTO box solely), as I stated before. This narrows down where the problem lies.
    Please keep us posted on what they find, as I'm very curious to what is causing it to hang up.
  10. SL3406
    SL3406 Medium Load Member
    550
    1,482
    Jan 10, 2011
    Oklahoma
    The PTO is disengaged by a spring when the air pressure is removed. The air control in the cab may not be turning off the air pressure. That would explain why both the old and new PTO have the same problem. Have your husband remove the air line from the PTO. If the spring is functioning correctly that would be the easiest way to disengage it.
  11. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    My guess, since the PTO has the same problem after the PTO was replaced, then the problem is in the switch. An important part of the switch is dumping the air pressure in the line when off, which is often overlooked. The switch may stop air from going to the PTO, meaning it may seem OK if it's unhooked, (blows air when on and stops when off), but if it cannot release the pressure in the line, the PTO will not come out. Do you hear the air release when it's switched off?
    If the switch and air lines are OK, then you'll have to drain the trans. Pull the shifter housing off and operate it manually, check for proper lash. If it will not move, then it's in the PTO. If it works good manually and lash is good, then the problem is in the shifter housing.
    As others have already said, it is a very simple thing. You need a new mechanic. If you find that the PTO was shimmed wrong, be sure to point out that if they put on a new Chelsea PTO, it came with a very detailed operation and installation manual.
