Help please. On the side of the road - electrical issue w/ codes
Discussion in 'Volvo Forum' started by Atlaw4u, Feb 9, 2021.
  1. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    Truck starts and idles fine and the accelerator pedal works normal while sitting in neutral. When I start driving I get check engine and loose almost all power. It feels like a derate mode.
    The codes are below. Any advice is appreciated.
    FMI=5 - Current Below Normal Or Open Circuit.
    SPN 558 Accelerator Pedal 1 Low Idle Switch.
    FM1=4 - Voltage Below Normal or Shorted to Low Source
    SPN 3509 Sensor Supply Voltage 1
  3. GYPSY65
    GYPSY65 Road Train Member
    1,957
    5,263
    Nov 16, 2012
    SW FLA
    Bump
    just moving it to the top for you
    Bad place to be
  4. Atlaw4u
    750
    1,131
    Jun 8, 2018
    Now while sitting for a bit and after doing a reboot I have the below code.
    FMI=2 - Data Erratic. Intermittent or Incorrect
    SPN 639
    FMI=4 - Voltage Below Normal, or Shorted to Low Source
    SPN 3508 Sensor supply voltage 1
  5. 86scotty
    86scotty Road Train Member
    4,628
    12,599
    Aug 27, 2017
    Appalachia
    You've got a voltage problem. Condition of batteries (new/old)? Got a battery tester? If they are good clean terminals and especially the battery shut off switch. It's a known weakness on Volvos.
    If you shut off the truck does it turn over weak or strong? Edit: Sorry, I just reread your first post. Maybe not batteries if it starts strong but definitely a wiring problem. Wiggle all the plugs at the ECU's.
  6. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    Also check the grounds
    86scotty Thanks this.
  7. Atlaw4u
    750
    1,131
    Jun 8, 2018
    And the fun part, I may be outvof phone service in a few miles. It's always an adventure.
  8. GYPSY65
    1,957
    5,263
    Nov 16, 2012
    SW FLA
    I would still maybe check all battery connections and make sure clean and tight
  9. Atlaw4u
    750
    1,131
    Jun 8, 2018
    I cleaned the battery terminals. I'm on the road. So far so good.
    InTooDeep Thanks this.
  10. GYPSY65
    1,957
    5,263
    Nov 16, 2012
    SW FLA
    So it fixed itself or you think it may have been terminals?
    I hate it when my truck fixes itself. I like that it works but hate I don’t know what happened
    xsetra Thanks this.
  11. Atlaw4u
    750
    1,131
    Jun 8, 2018
    Not sure. I cleaned the battery terminals and I did find one small wire going to the starter that had a rub in it. I taped it up.
    10 miles on, so far so good.
    GYPSY65 and Snailexpress Thank this.
