Help on injector height cat 3406e
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Flightline, Jan 12, 2014.
  1. Flightline
    Flightline Road Train Member
    2,345
    1,165
    Oct 1, 2011
    Almost There
    Anyone know of the injector height setting for a cat 3406e?
    Do you use a cat tool or just a height gage?
    Or is there a better way to set this when running overhead on cat.
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    either will work. don't quote me but I think the height is 3.07, but make sure I don't have my book with me to verify.
    Cetane+ and Flightline Thank this.
  4. Flightline
    2,345
    1,165
    Oct 1, 2011
    Almost There
  5. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    The tool is the best way but you can use a depth mic.
  6. Flightline
    2,345
    1,165
    Oct 1, 2011
    Almost There
    Anyone know of the tool part number ?
  7. Superhauler
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    yeah inches, sorry about that.
  8. Flightline
    2,345
    1,165
    Oct 1, 2011
    Almost There
    Is that 3 inches with rocker pushing down like the detroits or in the up position?. Hope I worded that correctly.
  9. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    9U-7227
    78.0+/- 0.2mm
    3.07+/- 0.01 inch
    Flightline Thanks this.
  10. Gear head
    532
    91
    Apr 1, 2012
    Belair,md
    Inj in non loaded. Find out the adjustment procedure for the cat it is easy.
  11. Flightline
    2,345
    1,165
    Oct 1, 2011
    Almost There
    You sure the 3.07 inches is correct in the non loaded position. I'm assumming your meaning nonloaded is without the cam lobe pushing against it.
    I'm measuring from the block head to the top of the injector. With the injector at it's high position.
    This is on a 1LW 3406e motor.
    I think I was reading a current reading of 4 inches so I must be measuring from the wrong position.
