Help on bridge law formula for semi dump
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by T-800, Aug 24, 2018.
  1. T-800
    T-800 Light Load Member
    98
    45
    Sep 20, 2014
    Frankfort, IN
    im trying to figure out if I can get a shorter dump trailer and still clear 80k. My truck is a 250” wb so is the formula based on steer axle to trailer axle, or tandems to tandems? I know most pleople run 40’ frameless, but if I understand the formula right, I can get a 36’ and still be 80k. Shorter the trailer, shorter the dump height. If anyone can help me figure this out, I would appreciate it. I’ve looked over the formula many times and can’t figure it out completely.
  3. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,822
    Dec 7, 2015
    OK
    I personally don't pull an end dump but a good friend of has been for years. He's got a 260" Pete with a triaxle 28' full frame. The problem with going with a shorter trailer is you run into problems with the inner bridge (drives to trailer) so you've got to have more rubber on the road to get to 80k gross.
    brian991219 Thanks this.
  4. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Without knowing your location and whefe you plan to run its hard if not impossible to give you an accurate answer.
    MartinFromBC Thanks this.
  5. T-800
    98
    45
    Sep 20, 2014
    Frankfort, IN
    Indiana only. Sorry I forgot to mention that
  6. special-k
    1,523
    3,258
    Dec 27, 2008
    Iirc you should be fine at 38' l know a 26' is good for around 73000lbs gross on the interstate. I used to haul b-trains into Gary Indiana. Without a permit we would split them up at the mi-ind line. The lead was good for 80000lbs gross and the pup was good for 73 and change. The reason we were told was the lead was about 38' feet long to the rear axle of the triple. The pup was only 27'? To the rear axle of the tandem. So they trimmed the gross weight back. You also had to have the axles tight together to get the inner spread needed. Meaning a 26' pup with a 9' spread got its weight knocked back for that reason too. Don't take these numbers for gospel as its been at least 15 years since l ran trains into Indiana. Good luck on your plan. If you run into a mi-ind steel hauler theyll know all the ins and out of it.
  7. T-800
    98
    45
    Sep 20, 2014
    Frankfort, IN
    I’ve already seen both of those and can’t figure it out. I just don’t want to buy a shorter trailer and not be able to gross out, but I want to buy the shortest I can since I have lime contracts this winter and don’t want a 40’ in the air in the fields if I don’t have to. Hopefully someone will chime in because I can’t be the first with this setup and question
    NightWind Thanks this.
  8. NightWind
    NightWind Road Train Member
    2,619
    18,593
    Nov 11, 2006
    Sunny South, AL
    As long as you have 51 feet between the center of your front axle and the center of your back axle you should be fine with 80,000
  9. NightWind
    2,619
    18,593
    Nov 11, 2006
    Sunny South, AL
    Figure 6
    Now check axles 1 through 5 (Figure 6)
    Actual weight = 12,000 + 17,000 + 17,000 + 17,000 + 17,000 = 80,000 pounds.
    Maximum weight (W) = 80,000 pounds (Bridge Table for "L" of 51 feet and "N" of 5 axles).
    Therefore, this axle spacing is satisfactory.
  10. T-800
    98
    45
    Sep 20, 2014
    Frankfort, IN
    That must be why some guys stretch the trucks. This is the figure I saw and what made me question if I needed a 40’. I’m only running in Indiana so scale houses aren’t really an issue. But I just want to make sure
