Help... no oil pressure on Cummins ISX 15
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by GatorKenworth001, Dec 5, 2019.
  1. GatorKenworth001
    GatorKenworth001 Bobtail Member
    23
    7
    Jun 9, 2013
    Is it possible for oil pump to just wear out? Oil pressure had been gradually decreasing that last 7 weeks. Pressure came way up significantly after oil and filter change, but dropped back down after 4-5 days. Yesterday while in shop to get starter replaced, had oil filter changed again. We have 0.0 oil pressure now. Gauges and sensors check out good. Need expert advice.
    Thanks
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    Check it with a mechanical gauge to confirm the electric gauge is working? And yes oil pumps can wear out but sounds more like you’re having issues with the pressure relief valve thats in the oil pump.
    AModelCat Thanks this.
  4. GatorKenworth001
    23
    7
    Jun 9, 2013
    They put a manual gauge on it, still no oil pressure.
  5. GatorKenworth001
    23
    7
    Jun 9, 2013
    We checked the relief spring and plunger on top of filter housing. It seemed fine. But is there a pressure regulator in the pump also??
  6. GatorKenworth001
    23
    7
    Jun 9, 2013
    Did you see my replies?
  7. Roberts450
    2,237
    3,635
    Feb 6, 2016
    Im not 100% sure but the ones on the filter housing is probably for by-passing a plugged filter and yes there should be a pressure relief built into the pump.
    pushbroom Thanks this.
  8. Roberts450
    2,237
    3,635
    Feb 6, 2016
  9. GatorKenworth001
    23
    7
    Jun 9, 2013
    Ok. Might be valve in pump then.
  10. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Yes there is a regulator in the pump. I think I would be looking for other damage or at least pulling a main or rod cap while you are down there.
  11. GatorKenworth001
    23
    7
    Jun 9, 2013
    Lower end is all brand new about 139,000 miles ago.
