Help! Multiple air leaks. pic included
Discussion in 'Trucks [ Eighteen Wheelers ]' started by wr2001, Mar 21, 2016.
  1. wr2001
    wr2001 Light Load Member
    88
    18
    Apr 27, 2012
    Las Vegas
    2006 volvo vnl
    I have a constant leak from what appears to be the green hose, where it meets the valve. Is it a bad valve or is it just a bad fitting on the hose? How do I repair it? Do i just pull the hose or do i pull the entire brass fitting?
    I have also noticed a leak when i press on the brake pedal. I think its coming from the leveling valve though. Are they connected or do I need to pinpoint which drum or brake line is leaking? Could it be the green hose?
  3. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    Pull out the line, trim off a 1/2inch, and try to reseat it. If it still leaks replace the valve. Also spray it with some soapy water to see if the leak is coming from the line fitting or elsewhere.
    wr2001 Thanks this.
  4. Dub21
    Dub21 Bobtail Member
    10
    Mar 21, 2016
    Use some soapy water to confirm where the leak is.
  5. AModelCat
    154,368
    Spray soap and water on the hoses and look for bubbles. Those are push on fittings. IIRC to release the hose from the fitting you need to push in on the hose, pull back on the little collar, then pull the hose out.
    The air suspension leveling valve shouldn't be interconnected with the service brakes.
    25(2)+2, rachi and wr2001 Thank this.
  6. wr2001
    88
    18
    Apr 27, 2012
    Las Vegas
    ok thanks il start looking for the brake leak.
  7. TAfool
    TAfool Medium Load Member
    631
    850
    Dec 8, 2012
    To release a quick connect:
    • Bleed off air pressure.
    • Push inward on the tube.
    • Simultaneously push inward on the small collar.
    • Hold collar in.
    • Pull tubing out.
    TA
    silver dollar, rachi and wr2001 Thank this.
  8. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    Those push in plastic fittings are a joke. Bleed off air and see if it will push in more. Or like one post said pull off line cut half inch off and push back in.
  9. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Do not cut tubes it will not help. just go to the Volvo dealer near you and buy new O-rings and collars, It is cheap.
    Repalce all O rings and collars one at the time so you don't mess tube location. You can post picture for everyone how is O-rings cracked and dry. Search on youtube how it to do
  10. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    Volvo uses brass quick disconnect fittings, not plastic, and cutting off the air line doesn't work, you need to replace the brass fitting with a new one and your leak will be fixed.
    The leak is caused by a non serviceable O-ring inside the brass fitting.
    It is s common problem after so many years.
    The valve in the picture has non serviceable quick disconnect fittings, you may need to replace the whole valve.
  11. Confused
    Confused Light Load Member
    224
    270
    Sep 22, 2009
    somewhere else
    It's a Volvo, you'll Fix one air leak, and a day later you'll have another air leak.
    jaykelz7 Thanks this.
