Help mounting my 32 in TV
Discussion in 'Schneider' started by tazman74, May 21, 2015.
  1. tazman74
    tazman74 Light Load Member
    254
    119
    Feb 27, 2013
    Albert Lea, Mn
    I need some ideas on mounting my 32in tv in my cascadia. I don't really want to drill holes but I will if I must. I only have a year lease on it. I WILL be upgrading in a year need a better APU its 87 outside and 86 in here with the idle free running. (truck is now running to cool me off) but sorry any help would be great. before you say it 32in is a bit bigger then I needed/wanted but the price was good.
  3. Hegemeister
    Hegemeister Road Train Member
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    At Walmart I bought a "flat screen strap mount". Just a strap with reinforced eyelets. (It's designed to stabilize a TV on an entertainment unit). Connected the eyelets to the TV and tied the trap to the upper bunk support. I duct taped a towel behind it to protect the TV in transit. No problems.
    I also have the Cascadia till October. Just want to get thru the 1st year.
    tazman74 Thanks this.
  4. tazman74
    254
    119
    Feb 27, 2013
    Albert Lea, Mn
    do you have some pics? if so that would be great
  5. rz14nj
    rz14nj Light Load Member
    153
    96
    Jun 12, 2012
    my tv is 24 inches, but it might still work for you.. mine is mounted to the side wall of the cabinet behind the passenger seat with 2 c clamps and a swivel wall mount.
    it will probably take a beating going down the road, you could always leave it laying on the bunk and just hang it on the mount when you're parked for the night.
  6. sadwar
    sadwar Road Train Member
    2,143
    3,370
    Jul 8, 2012
    Lockport, IL
    I built a wood mount for my 32" TV that wraps around the top bunk, folds up flat against it for transport, and swings down for viewing while laying in bed...
    Check out my thread North by Northeast for pics....
    Indiana RED and tazman74 Thank this.
  7. tazman74
    254
    119
    Feb 27, 2013
    Albert Lea, Mn
    Thanks took a bit but I found it. I like it
  8. dieselfuelonly
    dieselfuelonly Road Train Member
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    I wouldn't go drilling holes in a lease truck if you're planning to turn it back in. They might charge you to replace any panels that you've drilled through/into. They want the trucks turned in in nice shape for the next driver, not full of holes. Sadwar had a cool setup.
  9. tazman74
    254
    119
    Feb 27, 2013
    Albert Lea, Mn
    I think I will be doing that. I did call my finance rep and he said it's ok to mount a TV mount but it stays with the truck.
  10. sadwar
    2,143
    3,370
    Jul 8, 2012
    Lockport, IL
    If you want some more details on how I did it, just let me know..
