Help me understand the 8 days/70 hours/34 hour reset particulars
Discussion in 'Experienced Truckers' Advice' started by 762x39, Dec 7, 2015.
  1. 762x39
    762x39 Bobtail Member
    39
    10
    Oct 16, 2015
    Hello. I've been driving for a little while now but can't seem to understand the 8 day rule. I thought I understood it but now I'm confused again.
    Is it required by law to do a 34 hour reset? Someone told me that if I run less then 8 hours a day then I never have to do a 34 reset, even after 8 days of driving. Now I am confused...I though that you needed to do a 34 reset at the end of 8 days regardless of how much time/hours you have left.
    I am currently on my 8th day with 3:30 hours left on my 70. I am suppose to gain 10:51 hours at midnight tonight....I'm confused.
    Can someone explain this to me please. I was told I'll make less money if i do 34 resets every 8 days. I want to make more money. Hours to be gained in 2 days is 4:58. I'm confused.
    Thanks
  3. IronWeasel80
    IronWeasel80 Medium Load Member
    387
    375
    Sep 4, 2015
    Belen, NM
    I'm sure someone will be along to correct me if I'm wrong since I haven't been OTR for several years, but from what I remember the idea is that you always have enough hours falling off your 8 day rolling 70 to keep you from hitting 70. I assume you're perfectly clear on the 11 / 14 hour rules, so I won't bother with those.
    HOS Regulations as a refresher:
    https://www.fmcsa.dot.gov/regulations/hours-service/summary-hours-service-regulations
    • If you run 10 hours every day for 7 days, you'll hit your limit of 70 hours and have to do a reset.
    • If you run 8 hours per day for 8 days, you end up with 64 hours at the end of day 8.
    Now, since you have 64 hours used and 6 available on the end of day 8, when day 1 "falls off" you'll gain another 8 hours which leaves your previous 7 day total at 56 hours used and 14 available. Just rinse and repeat and you'll never bump up against the 70 hours in an 8 day period and won't be required to take a 34-hour reset.
    A lot of drivers in your situation would just do a 34 to reset the rolling 8-day period, but that prevents you from making any money for those 34 hours. If you only do 8 hours per day instead of 10, that gives you a "loss" of 16 hours over an 8 day span but it's fewer hours lost when compared to sitting for a full 34 hours.
    doug79705 and 762x39 Thank this.
  4. Longarm
    Longarm Road Train Member
    1,292
    30,754
    Jun 2, 2011
    34 hour resets are not mandatory. They come in handy if you've been burning it down the past 5 or 6 days though.
    With your current hours, I wouldn't bother with a 34 assuming you have freight.
    762x39 Thanks this.
  5. peter_x
    peter_x Light Load Member
    89
    51
    Aug 24, 2013
    I think it's 8.75 hours a day and you never need a reset.
    762x39 and mountaingote Thank this.
  6. buzzarddriver
    3,507
    10,013
    Feb 1, 2011
    Dallas, TX
    And to answer your question on the 34 hour reset.
    There is no law that says you "must" take a 34 hour reset. It is an option that is available, if you wish to use it.
    If your scheduled to be off for 34 straight hours, then you can use it to reset your 70 hour clock. But if your freight runs do not allow you to sit for 34 hours, then you run on recap and use the hours available you regain each midnight.
    762x39 Thanks this.
  7. Allow Me.
    10,642
    12,097
    May 28, 2009
    Rancho Mirage, Ca.
    Yeah the reset rule is to give you a "clean slate" so to speak. Use it if you are sitting waiting on a load for at least 34 hrs, or, if you're home for the weekend at least 34 hrs. Otherwise, run off your recap, or, if you anticipate running hard and are only picking up 3 hrs a day for the next few days, then park it for 34 (if you can) so you'll have a fresh start. Let dispatch know your situation at all times. They don't appreciate giving you a hot load then you tell them the next day you don't have much hrs.
    fastlanedanny and 762x39 Thank this.
  8. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    Ding ding ding...we have a winner!
    jammer910Z and 762x39 Thank this.
  9. farmboy73
    farmboy73 Medium Load Member
    549
    681
    Oct 23, 2015
    Knoxville, TN
    So is the "recap" the recapturing of the hours that roll off each day from 8 days prior?
    762x39 Thanks this.
  10. peter_x
    89
    51
    Aug 24, 2013
    Exactly.
    762x39 and farmboy73 Thank this.
  11. IronWeasel80
    387
    375
    Sep 4, 2015
    Belen, NM
    Yep...it lists the hours you'll have available tomorrow and since it's a rolling 8 day period, the previous 8th day drops off and you have those hours available.
  12. peter_x
    89
    51
    Aug 24, 2013
    The JJ Keller logbooks have a space on each page where you write down both the 7 and 8 day on-duty totals. I believe they do this so you can subtract the two numbers and find out what you have available tomorrow without having to flip back 7 or 8 pages in your logbook. Someone correct me if I am wrong.
