hello all , can you help me with this valve , it's on a 3 axle flatbed trailer , and i look for information on that one
thanks in advance
Help me to identify air valve on a trailer
Discussion in 'Trucks [ Eighteen Wheelers ]' started by sunsation288, Jan 17, 2015.
Emergency valve.
many thanks wichris for the fast respond , i can't find any info on emergency air valve ? , they have another name ?
Maybe spring brake valve ?
You will probably have to remove the valve & get the model number off of it to be sure.
That would be the easiest way. -
What you have there looks like a standard Bendix SR-2 spring brake valve. There's a few parts #'s for it, which are all the same valve, but they come in few different size reservoir ports.
seems to me it is not sr-2
it is park brake emergency and release valve, but not sr-2
can u tell me where red lines run? to brake chambers ore to park brakes?
Is there ABS on trailer, how many spring brakes? -
Sorry guy for the late reply , it was a SR-5 valve for a three axle trailer , many thanks for all your help !!
