Help find wheel hub assembly for steer axle on a 2000 FLNR FLD
Discussion in 'Ask An Owner Operator' started by zinita17601, Jul 12, 2024.
  1. Ridgeline
    22,599
    119,963
    The dealer has access to the build sheet for the truck, you give them the full vin number and they can print it off for you. The build sheet lists all the major components and the manufacturer part numbers for that component, so it would list the axle manufacturer and part number.
    Dino soar Thanks this.
  3. abyliks
    abyliks Road Train Member
    3,993
    9,384
    May 2, 2010
    ludlow MA
    going to have to change both at that point then so they match
    might even look durca wrecked truck and just swap the whole axle
  4. zinita17601
    zinita17601 Road Train Member
    1,318
    1,603
    Aug 19, 2010
    lancaster pa
    I agree,you make perfect sense.however i dont have the mechanical skills to do it myself and both the part swapping shops i took the truck to can’t think outside the box
  5. jamespmack
    216,317
    Almost certain the were Conmet hubs. Last I knew. Still avaliable.
    Finding alot of younger parts people at dealership say "Not avaliable" when they are to lazy to look up stuff they are younger than and Freightliner actual does support most everything still.
    FLHT and Sons Hero Thank this.
  6. philg
    philg Bobtail Member
    10
    Dec 30, 2014
    Pennsylvania
    Hello....I to have this set up ....how did you make out finding the KIT 1432 ? Did Transtec locate some ?
  7. zinita17601
    1,318
    1,603
    Aug 19, 2010
    lancaster pa
    It’s discontinued as they don’t make them anymore and if you find them its $1500 a piece.better off getting a used axle with the updated hubs and rebuild it,its cheaper.
