Help! Exhaust leak?? KW T680
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by TexasTruckin19, Apr 20, 2021.
  1. TexasTruckin19
    TexasTruckin19 Bobtail Member
    10
    6
    Nov 6, 2019
    We noticed a small melt in the panel of the truck in the passenger side. That hole has now gotten huge!! Any ideas where this is coming from?? We though it was from this exhaust pipe and swapped it out but didn’t help. Panel kept melting.
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Being pre-dpf, look for soot stains or feel for air escaping when exhaust is cool. Starting a regen would help pinpoint the leak fastest. You use new gaskets and clamps on the DOC inlet elbow?
    BoxCarKidd Thanks this.
  4. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,393
    Mar 18, 2021
    St Malo mb
    Isn’t that where the dpf is located ? I had a 2015 it was constantly leaking from dpf somewhere for two years . They never found nothing but problems went away when they changed it on warranty after getting head office involved and having proof with a carbon monoxide detector. I suspect when yours is doing a burn it’s leaking badly and heat is burning plastic.
  5. SmallPackage
    5,273
    16,440
    Dec 20, 2019
    Marion Texas
    This is why new emission trucks catch fire and burn to the ground. The real reason why they don’t want you to idle.
  6. PoleCrusher
    PoleCrusher Road Train Member
    7,503
    82,190
    Aug 26, 2014
    LLMF
    That's where the DOC is located. DPF might be restricted, causing a heat build up. I wonder if it's possible that your doser is running too hot?
