Help! Cummins isx oil temp too hot
Discussion in 'Trucks [ Eighteen Wheelers ]' started by vadim2200, Dec 5, 2010.
  1. vadim2200
    vadim2200 Light Load Member
    128
    36
    Nov 21, 2010
    K, so the unplugged EGR helped lower temp by about 6F, but the problem with oil is still there. I also just noticed after sleeping overnight with engine totally off, i turned the gages and checked out oil temp and it was 85F, and it seems a little high, i have a feeling that the temp sensor could be bad. Because before after after having truck shut off i remember that my temp was around 60-50 on days like this. Does anyone know where is this oil temp sensor i want to replace it before doing the T-stat?
  3. LostSoulCA
    LostSoulCA Medium Load Member
    343
    150
    Apr 7, 2009
    Visalia, CA
    I had a similar problem on my ISX 530. On a hill my oil temp would climb to above 250. Problem was a $32 water temp sensor. Look at your water temp. It should be running 180. If it is not, your problem is likely to be your water temp sensor. I spent a ton of money letting monkeys troubleshoot this. What a waste of money for a cheap little sensor.
  4. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    The oil temp sensor is located just behind the fuel filter, just below the back of the integrated fuel system module on the block. This sensor is both temperature and pressure.
  5. vadim2200
    128
    36
    Nov 21, 2010
    I took some shots, can you confirm what i showed is OIL TEMP SENSOR?
    Thank you
  6. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    no, that is fuel sensor. the oil sensor is directly behind that fuel filter, the sensor goes into the engine block itself. look directly behind and to the rear of that fuel filter and you will see the sensor in the block.
  7. vadim2200
    128
    36
    Nov 21, 2010
    Let me try again, is this it?
  8. country29
    518
    157
    Feb 27, 2010
    yes that is the oil sensor
    K.S. Brar and vadim2200 Thank this.
  9. Heavyd
    7,749
    6,184
    Feb 4, 2009
    Yep, that looks good. The sensor should have 4 wires going to it.
    K.S. Brar Thanks this.
  10. krockodile
    krockodile Bobtail Member
    24
    Oct 20, 2008
    San Antonio, TX
    Hey guys I have an ISX Cummins 565 engine that had the oil cooler replaced 8 months ago. It's in an International 9400I 2001 model. Why would this oil cooler fail again after only 8 months of running?? I perform all maintenance regularly on this engine with Mobil Delvac, 2 gallons of Lucas Oil Treatment. What gives on this?? Any help will be greatly appreciated BIGTIME!:biggrin_25521:
  11. Heavyd
    7,749
    6,184
    Feb 4, 2009
    How did it fail?
