Help choosing gear ratio X15 605hp 18 speed
Discussion in 'Ask An Owner Operator' started by Tormoz, Jan 12, 2021.
  1. Tormoz
    Tormoz Bobtail Member
    Jan 12, 2021
    Spec'n out a 2021 w990 and have a question: I'm usually loaded 80k step deck through PNW (all mountains) and dealer is suggesting 3.25 rear end on 22.5 lows, says it will be 1400rpm@70mph. I currently have 3.55 on an up-tuned 450 isx 13 speed super singles and sit around 1500-1600 rpm. Any opinions? Mpg not a large factor (I avg 5.8) And yes buying new because I've put over 1,000,000 on a 08 prostar and it is time to spoil myself.
    Thanks!
    Coffey, Vampire and blacklabel Thank this.
  3. Judge
    84,390
    3.36 is good for an 18 speed
    If you drop to the old 3.08 (bull hauler gear) it’ll drop your rpm to at 70 to around 1300ish but you’ll be splitting more.
    I’d say 3.36 will do a good job.
    Tug Toy, Vampire and baha Thank this.
  4. Spyro2112
    Spyro2112 Medium Load Member
    602
    412
    Mar 17, 2018
    Yep or stay with 55
  5. Tormoz
    Jan 12, 2021
    I think 3.55 will be too much with 605 hp, no?
    I was thinking bringing it up to 3.36 but nobody that I work with has a x15 performance. Good to know someone else has the same idea.
  6. abyliks
    abyliks Road Train Member
    3,746
    8,692
    May 2, 2010
    ludlow MA
    Do you do a lot of tall stuff? If not worried about height I’d go with an 11 22.5 and 3.36, better ride and a little longer life out of the tire with the usually heavier loads
  7. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Tormoz: Not entering the rear gear question. My opinion differs from most.
    Only saying congrats on the new ride. Have a friend, he is very happy with his 990!
    Best wishes :occasion5:
    Coffey Thanks this.
  8. 062
    062 Road Train Member
    6,142
    33,154
    Oct 20, 2013
  9. Accidental Trucker
    Accidental Trucker Road Train Member
    3,311
    7,219
    Jun 4, 2015
    We run 88K in the PNW with a 505 Paccar and 325s. It is working very well. If you drive more miles in ID, NV, UT, MT and WY, I’d go with the 3.25’s. If mostly OR and WA, 3.36.
    mrbucbuck Thanks this.
  10. Tormoz
    Jan 12, 2021
    I do, its why running the lows
    Thanks!
    Gotcha. Usually between Seattle and Chicago and lots of small stuff within PNW.
  11. Dynames
    Dynames Medium Load Member
    374
    298
    Apr 13, 2016
    Here, There and Yonder
    I have a 565/2050 X15, 18 speed with 3.25 rears on 24.5 lo pro. I’m right under 1400 at 70 mph and on flat or slightly rolling ground it is fine. The few times I’ve wandered into big hill territory it still did fine as long as I kept it above 1400 rpm. Hills that I would pull at 40-45 in my NXS Acert 475 the X15 would knock down a hill at 5-10 mph faster and a gear higher. 475 Acert had an 18 and 3.36s on lo pro 24.5 for comparison.
    My next truck I’m spec’ing another 565/2050 with an 18 but I’ll probably cut back to 3.36 or 3.42 on lo pro 24.5. Current ride is long legged and I have to constantly slow myself down.
    I’m loaded to 80k for nearly 2/3 of my miles, empty the rest and I average 5.5 mpg running the snot out of it. I do not baby it. Absolutely zero emissions or engine issues thus far.
    A 605/2050 in that part of the country would probably be fine with 3.25 on 22.5 tall or lo if you’re staying at 80k and under. If you want 24.5 though I’d bump to 3.36 or 3.42.
    Judge Thanks this.
