Help -- a year with this problem! SA 16 DTC P228F00
Discussion in 'Volvo Forum' started by dbny5000, Jan 28, 2022.
  1. dbny5000
    dbny5000 Light Load Member
    87
    55
    Dec 24, 2011
    San Francisco, CA
    2017 Volvo VNL + D13
    Every time this truck hits a hill, it generates this code and significantly loses power for the rest of the day. We have done all the basics, like check fuel filters and even changed a harness (I believe) for the EPRV system under the valve cover. ALSO, we got a hold of an EPRV-delete kit and it was installed with reprogramming by Dothan Volvo. Driver took it out on the first load and same problem returned. Any ideas?????? It's been one thing we can't solve -- and there's very little info on the Web about this code.
    SA 16 DTC P228F00
    He's able to get back to speed on flat ground and make his trips but his power is quite reduced. So it's certainly not a 5 mph derate, and I don't suspect it's a derate of any kind because there's no warning or advisory on the dash saying he's derated.
    He DID have a code that pointed to the particulate-matter sensor, but those allegedly do not cause de-rates or affect performance. Is that also for sure on these D13s? That code is DTC P24B100
    Any help or insight would be appreciated!
  3. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    need to look at pressure sensor on the rail or also it can be caused by one of the pumping injectors working to much or overtime i should say. did volvo say anything about this code in particular.
  4. dbny5000
    87
    55
    Dec 24, 2011
    San Francisco, CA
    Thank you. That's a good new avenue for us. They didn't advise on that code that I know of, but the driver has been the contact. I should ask him for a copy of the paperwork to see if there were any comments.
  5. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    usually every code they have comes with dummy diagnostics is what i call it it will give you an idea of what is causing the fault i would check the fuel psi sensor on the rail they are notorious for failures also harness has to be update with sensor as well.
  6. Mikhail
    Mikhail Bobtail Member
    Feb 21, 2022
    @dbny5000
    Have you guys been able to find out the problem that caused that P228F00 code?
  7. dbny5000
    87
    55
    Dec 24, 2011
    San Francisco, CA
    Sadly we are still chasing this problem. He's still losing power on even tiny hills and still getting the P228F00. I've confirmed this morning he has the correct new fuel-rail-pressure sensor in, Part No. 23488939, which is a Delphi component with its own part no. of 28672623. We've put that sensor in, changed the harness, done an EPRV delete, and this still happens. Whenever he hits a hill, he can expect the power to drop drastically. Oddly he won't have the same problem fully loaded and flooring it to build speed on an onramp. The condition lasts for the whole day after that. After a shutoff and restart, it goes away. Because of this, he's staying in flat states.
    We're wondering about external causes now, even crazy ones, like ping-pong balls or sand in the fuel tank or something restricting fuel flow in a filter housing -- anything that would cause erratic fuel pressures. The code description for P228F00 is "Fuel Pressure Regulator Exceeded Learning Limits -- Too High, No Sub Type Information." Is there even really a "fuel-pressure regulator" on the engine??
    Thinking of diagnosing with help of a dyno???
    STILL STUMPED. Help apprciated.
  8. Jack jiao
    Jack jiao Bobtail Member
    Apr 30, 2022
    How about Turbo working condition?i meet same code and turbo psi always 15psi around
  9. Another Canadian driver
    Another Canadian driver Road Train Member
    1,181
    4,263
    Nov 14, 2021
    ALBERTA
    P228F00 DTC Fault Code
    Code Meaning
    The fuel pressure regulator 1 has exceeded the training limits - too high a pressure
    In some technician opinion you have a stuck close valve.
    The pressure gets too high and a temporary engine de-rate happens.
    The fuel pressure should be regulated by a return valve.
    Not my personal opinion. I'm just a driver. Retired driver.
    I just asked a friend. Maybe it'll help you. Maybe not.
    Good luck.
  10. Yatesboi
    Yatesboi Bobtail Member
    4
    5
    Jun 29, 2022
