Heavy Haul Vs Regular Haul
Discussion in 'Questions From New Drivers' started by DevJohnson, Jul 3, 2018.
  1. DevJohnson
    DevJohnson Medium Load Member
    340
    153
    Nov 27, 2017
    Is there much difference to pulling heavy haul (100lbs+) to pulling regular loads? Of course I’m moving slower and gotta take grades slow as well but as far as scaling is there much difference?
    IluvCATS Thanks this.
  3. TripleSix
    134,766
    100000lbs is not heavyhaul. That's every single day in Canada and in all the States that border Canada.
  4. DevJohnson
    340
    153
    Nov 27, 2017
    Okay well here in the US where most of are, I’m curious to know what diffferences there are
  5. TripleSix
    134,766
    In the US, where most are, 100000lbs is not heavy enough to be heavyhaul.
  6. DevJohnson
    340
    153
    Nov 27, 2017
    If you’re going to come on here and argue for the hell of it just leave cus I’m not up for it, I want my question asked
    MBAngel Thanks this.
  7. 03machwon
    03machwon Medium Load Member
    305
    426
    Jun 19, 2013
    He speaks the truth....100k isn't really heavy haul...you can scale that on 5 axles in alot of places.
  8. DevJohnson
    340
    153
    Nov 27, 2017
    Okay but I’m new and I don’t know how heavy is heavy when it comes to trucking all I know is it’s usually around below 80k and the company I’m trying to get in with calls anything above 80 heavy haul. I’m gonna delete this and find some help else where
  9. TripleSix
    134,766
    Swift calls their little 6 axle gig in Washington State "heavyhaul." TMC calls their guys that pull RGNs "heavyhaul" and they dont even pull over 80k. If your company is telling you that 80000+ is heavyhaul, they are a joke. That's like someone saying tennis is a contact sport.
    The difference between 100k vs 80k is the same as 80k vs 60k. If you are 60k coming out of the mountains on a 6 mile, 6 percent grade, what precautions do you take? You put the transmission in the big hole, set the jake on the highest setting and let the jake control you all the way down. Do you run 80k the same way? Nope, you drop 3 gears or so, where the jake will hold you at 45-55 mph, and you creep it down at that speed. At 100k, you do the same thing, but you choose the gear that will hold 25-35mph, and let the jake scream all the way down and do your best to stay off the brakes.
    Heavyhaul is anything deemed by the State or Province as a "Superload" where the superload rules apply. And you dont usually see those rules until you go OVER 160k on a non divisible load. Or over 17ft tall. Or 150ft long. Or 18ft wide. All non divisible.
  10. shogun
    shogun Road Train Member
    6,075
    72,166
    Jan 23, 2009
    Doing a regen
    Don’t listen to @TripleSix,
    He just hauls multi axle loads and overlength loads for a living.
    Woodys, SavageMuffin, stwik and 14 others Thank this.
  11. Slim51
    Slim51 Light Load Member
    275
    345
    Sep 22, 2017
    Maine
    You already asked it man. Now listen to the answers
    Lepton1, Oxbow, 88 Alpha and 1 other person Thank this.
