Heavy Haul truck setup questions
Discussion in 'Heavy Haul Trucking Forum' started by UltraZero, Feb 15, 2014.
  1. UltraZero
    UltraZero Medium Load Member
    406
    96
    Jul 18, 2013
    So. Good day to all. I am looking to get information regarding heavy haul.
    It is my opinion, there are several levels of heavy haul. Heavy haul consists of loads above 80K or loads that are oversized/over dimension.
    That being said. in order to carry weights between 80-120K, my questions is kinda general.
    Can I use a Volvo, with a cummins ISX 500-600 hp, 18 speed tractor with a 13K -16K front end and 46K axles to do the job. Gear ratio is 3.58 to 3.70.
    Thanks
  3. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Yes, you'll be fine...... I have more or less the same specs and have hauled 107k with the truck for 6 years.
    I would guess your using a 3 axle trailer .....
    Warren Earp Thanks this.
  4. UltraZero
    406
    96
    Jul 18, 2013
    I haven't purchased the trailer yet, but, we are looking at something in that relm. RGN Double drop if possible.
    I know others out there love Petes and KWs, but, I like how the Volvo drives. I don't know if heavy duty frames are an option for Volvo 670/780s
  5. UltraZero
    406
    96
    Jul 18, 2013
    Has anyone out there seen a dual rear axle Volvo with an additional tag axle that can be raised??
  6. jorlee
    jorlee Light Load Member
    197
    83
    Feb 17, 2007
    ND
    Not a tag, but I have saw one with a pusher.
    Also heard (two summers ago) from a HH trucking manager out of Montana, that the Kenworth Drivers with ISX's were crying pretty badly because the new Volvo's with D16's were walking away from them on hills, each with the same trailer and load.
  7. TripleSix
    127,948
    Got a buddy of mine with a D16. Had his air compressor break off while under a load north of Las Vegas. The repairs at the Volvo dealer hit him for $16.5k.
  8. UltraZero
    406
    96
    Jul 18, 2013
    Wow. think think that's bad, Here is one worse. An 18 speeed transmission is about 10K to replace. Reman Transmission. Well, I heard if you blow up an Ishift transmission (Saw this happen at a Volvo Dealer) the replacement transmission was 30,000 dollars. The owner forgot to monitor transmission fluid and it was low. The clutch siezed up, burned up the transmission. All components were locked up.
    30K?? Hell, I can buy a used Volvo for that price. I like Volvos, but, when they break, they break hard. I have not come across a person with a D16 who liked it completely. I hear they pull strong, but, fuel mileage sucks.
    Since the winter has hit, I'm getting about 6.0 to 6.5mpg with my Cummins. (overall) (Not the same Volvo mention in the start of this thread) I thought when I had a valve adjustment, I lost fuel mileage. well, I think the loss was due to the engine not getting up to operating temp due to outside temps. I have not found a weather front for the Volvo yet.
  9. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    I don't care what you have under the hood, you start rolling down the road with 6 or 7 axles and north of 90,000lbs you can kiss that 6mpg number goodbye.
  10. Oscar the KW
    12,246
    28,114
    May 19, 2011
    Some days that is the truth.
