Heavy Duty Ramps: Hard to work with?
Discussion in 'Flatbed Trucking Forum' started by Bdog, Apr 18, 2017.
Thread Status:
Not open for further replies.
  1. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    95% of the time I haul the exact same load on my trailer. A pickup, and piece of rubber tracked equipment that weighs 20k as well as some misc stuff on the upper deck. My own equipment that I haul to job sites.
    I have a 53' step deck with a spread and a dovetail and ramps. It works fine but some states are not friendly to this. My load fits entirely on the 48' of the trailer. The dovetail and ramps are just there for loading and unloading.
    I have thought about selling this trailer and getting a 48' step. Maybe even tandem instead of spread as weight is not a problem for me. This would allow me easier maneuverability to the tricky places I go and I would be legal anywhere.
    My concern is I have never used the heavy duty ramps you just put on the back of the trailer. How hard are they to work with? Any issues loading a 20k rubber tracked machine on them on a regular basis?
    FerrissWheel and G13Tomcat Thank this.
  3. Bdog
    1,057
    877
    Nov 6, 2014
    Something like this is what I was considering.
    FerrissWheel Thanks this.
  4. soloflyr
    soloflyr Medium Load Member
    563
    1,687
    Nov 6, 2009
    Houston, Texas
    I believe it is @Hurst that uses that kind of setup. He uses it to load all kinds of stuff & seems happy with it. He would be the one to guide you on it.
    FerrissWheel and Hurst Thank this.
  5. passingthru69
    Yea untill he tries to ld to big of a dozer on it. Duck and covering now Hurst
  6. DDlighttruck
    DDlighttruck Road Train Member
    1,386
    19,918
    Dec 12, 2015
    A couple of our trailers have ramps that double as load levellers. I think rated at 24K. They work fine but they are borderline too awkward for one guy to handle. They're shorter than what you posted too. For every day use I wouldn't want them, once or twice a week would be ok.
  7. sawmill
    sawmill Road Train Member
    3,590
    66,720
    May 29, 2015
    Evanston, WY
    I have ramps like that, also have a 48' trailer. Ramps are rated for 23K per axle. Each ramp section weighs about 70 lbs.
    If you do it make sure you put ramp brackets to your upper deck too.
    Using them isn't too bad if you have room to do it right. Set ramps on ground, then pull forward so they're at back of trailer...this saves you from dragging or carrying them.
  8. Mattflat362
    Mattflat362 Road Train Member
    2,696
    5,723
    Feb 18, 2015
    Avon Lake, Ohio
    I have a set and they are super heavy!! I haven't touched them since I bought them and found them a spot in my garage! Mine are rated for 12k each....
    I have to figure out a way to mount some retractable wheels on one end or something...
  9. noluck
    noluck Road Train Member
    1,616
    11,683
    Jun 10, 2011
    greenville,sc
    They are a pain in the ###!
  10. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Its all good Carl.
    I stopped posting pics of all the equipment I've been sending up and down my ramps because it just seemed to infuriate you RGN guys.
    Man still has to eat,.. and those are what I specialize in. Thats my niche.
    Hurst
  11. Hurst
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I use the HD Ramps. I bought the kit from Universal Trailers in OKC. They have another place near Dallas if memory serves correct. Or if your in Wisconsin,.. HD Ramps themselves is located somewhere in Wisconsin. I'd have to look them up again.
    Anyway,.. the pieces are all rated 23,500 lbs each. Combined they will support 47,000 lbs. I cant legally scale that much,.. so its been a safe number for me. I send 30,000 - 42,000 lb machines up and down them on a regular basis. Both tracked and wheeled.
    Couple of things to consider. If you plan to stay with a 48ft step I dont think you will have the same issues that I was having with my 53'. I was getting some flex and sagging at the rear of the trailer. HD Ramps sells a brace that goes under the DOT bumper at the rear of the trailer. I picked one up a few months back and have been using it with great success. Trailer is much more stable now.
    Also,.. you will want to reinforce the rear mounting plates that come with the kit if you plan to load tracked machines on them.
    The biggest PITA with the ramps, especially since your coming from a dove tail will be when pulling them out and storing them back up. I've resorted to pulling the ramps out of the racks and leaving them on the ground and then pulling the trailer up until the ramps are at the rear. Then setting everything up. Saves your back from carrying them.
    They also sell stake pocket braces that allow the ramps to be used as load levelers. Or,.. can also be used to put your over size banner on instead of dragging it at the rear.
    The stands are adjustable,.. I've loaded everything from Mack Dump trucks up on them,.. to wheeled and tracked machines. Back hoes, rubber tire loaders, graders, excavators, dozers, track loaders, skid steers, boom lifts, Fork lifts, Fire trucks, military vehicles, cars and pick up trucks.
    Worth every penny IMO.
    If you have any questions,.. I can post pictures of anything you want to see regarding their usage.
    Hurst
    bigguns, Lepton1 and truckdad Thank this.
  • Thread Status:
