Heater controls not working
Discussion in 'Kenworth Forum' started by sowers25, May 13, 2012.
  1. sowers25
    sowers25 Bobtail Member
    6
    Inwood, WV
    I have a 02 t800 and it won't come off of defrost no matter what I have selected. Would it be an actuator or the switch?
  3. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Sounds like an actuator
  4. sowers25
    6
    Inwood, WV
    How do I get to the actuator to replace
  5. Scrapper
    Scrapper Light Load Member
    289
    83
    Jan 19, 2010
    Nashville, AR
    Call kenworth...they can...or ours will fax you the parts diagram that shows where it is.
    Try this, pull the dash panels, shut the door, run up till your air bleeds off then shut the truck down and listen for an air leak. You would be amazed at the number of them under the dash. I do not know if yours is air operated. We have W9's and T600's and they are. Those little lines like to come loose if you ever go in there and are not careful. You can normally trace where the lines go also. Kenworth does a good job of labeling everything in the dash for you.
  6. gonzo01
    gonzo01 Light Load Member
    74
    5
    Jun 14, 2010
    denver, co
    My t2000 2007 is doing the same thing;defrost only. found that hvac fuse was blown. replaced fuse and all ok for an hour or two. fuse continues to blow... Is there an electronic control unit (box) in this unit or air/electric actuators. anyone have a diagram???
    thx
