Heater blowing cold air
Discussion in 'Questions From New Drivers' started by a.walla75, Jan 12, 2013.
  1. a.walla75
    a.walla75 Bobtail Member
    I just started driving a few days ago. The cab heater in my truck works fiine but my cab heater isnt doing anything but blowing cold air. Any ideas on what to do?
  3. ralph
    ralph Road Train Member
    1,112
    632
    Mar 1, 2009
    At The Key Board
    Is your cooland levelup all the way?
    Are BOTH heater hoses hot?
    Are the taps open going to the heater core?
  4. keepitsimple
    keepitsimple Light Load Member
    157
    87
    Aug 2, 2011
    ontario, Canada
    what truck ya driving? if it is a Int we had a flap under the pass seat, that would not open ( or close) to allow heat to cab. The bunk heat worked 100% at the same time
  5. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    I read in LandLine that there is sometimes a valve to stop coolant from getting to the heater core. It was intended to increase air conditioning performance in summer months.
    What make, model and year truck do you have?
    Mikeeee
  6. Driver of the year
    Driver of the year Medium Load Member
    442
    249
    Sep 28, 2012
    Tampa FL
    Yea, theres like a spicket that you turn on the side of the Engine. like the other Driver said, they close it for the Summer Months.
  7. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    it's supposed to help with a/c efficiency. but every truck i've been in seems to blow 3 -5 degrees cooler with the valves on.
    dn't ask my why that is. but idon't shut em off anymore.
    it's also a pain when you go from one extreme to the other to keep turning off and on and back again. south to the north and back south again.
  8. Mack185
    Mack185 Medium Load Member
    448
    262
    Feb 25, 2008
    Not on a Macks, the A/C will barely work at all if you leave the valves open.
    Like the others have said, look for a little spigot like handle on the hoses that you see running into the firewall.
  9. jimvrg
    jimvrg Medium Load Member
    301
    82
    Jan 11, 2012
    yellville arkansas
    yep check the valves under the hood on the passenger side
  10. Elendil
    Elendil Heavy Load Member
    921
    626
    Mar 27, 2011
    Ottawa, IL
    On the KW I used to drive there were 3 vales that had to be opened to get heat............
  11. Anonymoususerreport
    Anonymoususerreport Bobtail Member
    24
    17
    Jan 13, 2013
    Sometimes there are 2 spickets on the engine, or under the hood.
    Another tip - if you can't shut the heat off in the summer "close the spicket"
