headlights dimmer than they should be need help
Discussion in 'Peterbilt Forum' started by heuchert, Mar 13, 2014.
  1. heuchert
    heuchert Bobtail Member
    7
    Alexnadria, MN
    I have a 1999 pete 379 it has the 7" single headlights. My high beams are as bright as my dims should be and my dims barely light up. I went and bought the xeon hid lights and also checked the ground and cleaned it up and there was no change. What else could be causing this?
  3. Flightline
    Flightline Road Train Member
    2,345
    1,165
    Oct 1, 2011
    Almost There
    Strange I had the exact set up.
    Headlight aiming helps little but didn't make enough difference for me.
    Was told lousy ground would make all the difference but apprently I didn't have lousy ground.
    Finally got me a pair of the 4"x5" double square headlights like wing style from the junk yard and twice as good.
    Sold the round ones on ebay for almost as much as I paid for the used 4 light style.
  4. Flightline
    2,345
    1,165
    Oct 1, 2011
    Almost There
    Also seen where one could buy true LED headlights and 7 times brighter.
    But hard to justify at such a high cost of $600 a bulb.
  5. heuchert
    7
    Alexnadria, MN
    My cousin has the same headlights on his 04 379 and his work even better than the double squares. The only thing he says to check is see if there is a voltage regulator for them or maybe broken wires. I plan on checking all the wiring over the weekend when I get home to see if that's the issue
  6. Excorcist1
    Excorcist1 Light Load Member
    222
    39
    Jan 11, 2012
    Chestertown, MD
    I have a different model but had the same issue. You can have a broken ground wire on either side and your lights will still work but won't be as bright. Make a long story story short check the wiring where your headlight harness's plug into the main harness. After replacing sockets on both sides I later found out it was the main harness rubbing against the frame under the front.Wiring broke right at plug just enough to get power but barely touching.
  7. heuchert
    7
    Alexnadria, MN
    that would make sense because for a while I would be driving and they would go from being so dim to having some brightness then back to dim and I noticed when they would go really dim my high beam light on the dash would slightly illuminate when the bright lights weren't on
  8. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Besides what others say check your alternator output. It's possibly getting weak. It should be up near 14.5V.
    If that's not it then check your headlight ground. It'll be up near the passenger headlight somewhere close. It could be corroded.
  9. heuchert
    7
    Alexnadria, MN
    my alternator is running a bit above 14 on the gauge. I looked at the connectors they all look good but on the right side (passenger side) I did see that there is a small ground wire running to a tech screw that is in the radiator mount with another wire that runs to the frame right up front and is grounded there. I cleaned that up and no change. I'm still lost on what it all could be
  10. CondoCruiser
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Did you remove the ground wire and clean under it. That's where it gets corrosion. You can't see it otherwise.
    Now is this all taking place after you installed the HIDs?
    Your high beams and low beams are two separate circuits with each having their own relay. They do share a battery feed and a chassis ground which I think you found. Check your voltage at the low beam socket, check your voltage on pin 30 at your low beam relay. Use chassis ground for your negative probe and not some ground wire. See if there is a drop between the two readings.
  11. Excorcist1
    222
    39
    Jan 11, 2012
    Chestertown, MD
    Exactly you probally won't see it. I would hit a bump and the right side would go out. I'd go to replace the bulb but it would light up then the left side would go out. Sockets would melt and I replaced them. etc, etc Had proper voltage reading on gage, good grounds but that 1 power wire on the right side arcing cause havock.
